Posted February 3, 20205 yr comment_592136 Hi there. New to the forum. Got a 1980 280zx a few months ago and I'm trying to sort out some dash issues. The only guage that works is the speedometer. Fuel, tach, temp, oil, voltage, and the clock all do not work. No dash lights either. I've checked my fuses in the passenger footwell and I've cleaned the battery and chassis ground. Any advice on what to try next and/or if these problems are related? Link to comment https://www.classiczcars.com/forums/topic/63532-1980-280zx-no-guages-except-speedometer/ Share on other sites More sharing options...
February 3, 20205 yr comment_592139 Did you use a meter to check for power at one side of the fuse? Might be a fusible link. Download the FSM and the wiring diagram and start probing. EL = electrical. The diagram is in the back of the chapter I think. https://www.classiczcars.com/files/category/14-280zx/ Link to comment https://www.classiczcars.com/forums/topic/63532-1980-280zx-no-guages-except-speedometer/#findComment-592139 Share on other sites More sharing options...
February 4, 20205 yr Author comment_592142 Thank you! Downloading it now. No power at the fuse box for that particular fuse. Would that indicate a fusible link is the culprit? Link to comment https://www.classiczcars.com/forums/topic/63532-1980-280zx-no-guages-except-speedometer/#findComment-592142 Share on other sites More sharing options...
February 4, 20205 yr Author comment_592144 Tried it again and now I have 12v at that fuse. Not sure why it didn't read the first time.... Link to comment https://www.classiczcars.com/forums/topic/63532-1980-280zx-no-guages-except-speedometer/#findComment-592144 Share on other sites More sharing options...
March 23, 20205 yr Author comment_595093 Ended up just being broken circuit boards behind the guage clasters. They're all working now! Link to comment https://www.classiczcars.com/forums/topic/63532-1980-280zx-no-guages-except-speedometer/#findComment-595093 Share on other sites More sharing options...
