20 hours ago, moozieman said:
great! ill keep an eye out for that. Headed over to the garage tonight
Okay. Completely different question now. I was able to get it running pretty steadily with the new gasket and everything, but it started a new issue... of course. The distributor started making a grinding noise and was rattling a bit as well. Sometimes the car doesn’t even turn over. It’ll start grinding and then stall. Any ideas?
It didn’t start doing it until after running for a while, not sure if that’s a coincidence or not.
Sounds like a bad distributor but that's just too easy to say. :victorious:
Here's my "go to" on everything 280.  This is a ZX dizzy but they're pretty much the same except for the matchbox ignition module.  You could read over it and maybe something will light that bulb in your head.  I know I've found loose ball bearings in mine when I first bought it.  It may be as simple as the reluctor being out of spec?
http://atlanticz.ca/zclub/techtips/distributorrebuild/index.html
Thank you Phillip for putting this together!  It's been a big help to a lot of us.  @240260280
9 hours ago, Zed Head said:
Take the cap off?  Look?
Looked into it a little. Can’t figure it out. There’s no consistency to the fails either. Sometimes it does it, sometimes it doesn’t. Mainly when I rev or attempt to put it into gear. Thoughts?
On 2/22/2020 at 10:29 PM, Zed Head said:
Post a picture with the cap off.  We don't even know what kind of distributor you have,
I'm not at the garage. I will upload a pic of my own, but maybe this is sufficient for now? This is my exact setup.
