Hitachi 280ZX Distributors
Av8ferg
Well, the only good new I have is that all the parts for my distributor rebuild have finally arrived. So I can lock myself in my garage without guilt and rebuild one maybe two distributors. Last part (breaker plate) arrived this AM. Really was surprised to see it arrive with all this chaos.
I'm with Zed Head, can't believe you found one.
I did a search for that same one recently with no success.
Congrats on locating one.
Thanks, maybe I got the last one, sort of like the last pack of Chicken Breasts I got from the grocery store today. It was $45 shipped, so it wasn’t cheap that’s for sure. But now I’m confident it should work.
  • 3 weeks later...
So I’ve made some good progress rebuilding this distributor.  The Atlanticz rebuild instructions are fantastic.
So I have carcasses and parts from 3.5 distributors (One I cannibalized in the yard because it was frozen to the front cover)
I have 3 vacuum advance assemblies.  I bench tested them and 2 of 3 were bad.  The good one looks rough...very rusty but it holds vac pressure and the plunger moves and holds.  I’m actually building 2 distributors, one a a primary and the other as a back up.  I went online to hunt down a new vacuum advance.  Of course they’re no longer in stock anywhere.  The part number is 22301-p7900 or 7901.   I did find some that look identical, Stanza and 200sx.  Parts numbers are different, but part looks exactly the same,  not sure if those would work,  look at links below.
first eBay link is titles 22301-p7901 but on the phone it has a different part number on the box 22301-D2100
https://www.ebay.com/p/1173306983
Another website says I can use a Standard Motor Product part VC351.  See this link, at the bottom is talks about different Nissan Vaccum advances compatibility with Standard Brand.
http://datsun1200.com/modules/mediawiki/index.php?title=Late-model_Vacuum_Advance
What do you guys think?
  • Who's Online   1 Member, 0 Anonymous, 857 Guests (See full list)
