Posted March 2, 20205 yr comment_593534 I've finally got my 1978 280z idling decently... Kind of. It's been really touch and go. My distributor has been doing this weird thing where it starts making a grinding noise and then stalls the engine. Doesn't do it 100% of the time, but when it does, it's typically when I rev the engine or attempt to put the car into gear. This is leading me to believe that it has something to do with the oil pump or spindle rod or something. I've attached some photos of my old distributor cap and rotor and you can see where there's been interference between the rotor and cap. I have since replaced the cap, but continue to experience the same issues. Any thoughts? Anyone seen this before? Link to comment https://www.classiczcars.com/forums/topic/63641-distributor-grinding/ Share on other sites More sharing options...
March 2, 20205 yr comment_593537 IMO, it's either bad dist. bearings allowing side play in the dist. shaft or a bad rotor. I had a cheap cap and rotor in my 521 that ended up looking like that. New Bosch products cured it. Link to comment https://www.classiczcars.com/forums/topic/63641-distributor-grinding/#findComment-593537 Share on other sites More sharing options...
March 2, 20205 yr comment_593569 Mine used to wobble as the shafts do get worn - you can see it in the video below. But it never - as far as I am aware - interfered or made grinding noises. Try to do what I did with mine in the video and see if you have more movement than I did. (And that was my old engine where the PO went wild with the blue paint!!) [emoji849] Link to comment https://www.classiczcars.com/forums/topic/63641-distributor-grinding/#findComment-593569 Share on other sites More sharing options...
March 2, 20205 yr comment_593573 If I recall right there are different size distributor caps out there. I think that the ZX cap might be a hair smaller. If you put your 280Z cap on a ZX distributor it might be loose. Or if you went to the auto parts store and asked for a 78 280Z cap, but you have a ZX distributor. A possibility, I think. Link to comment https://www.classiczcars.com/forums/topic/63641-distributor-grinding/#findComment-593573 Share on other sites More sharing options...
March 3, 20205 yr Author comment_593596 On 3/2/2020 at 11:13 PM, Zed Head said: If I recall right there are different size distributor caps out there. I think that the ZX cap might be a hair smaller. If you put your 280Z cap on a ZX distributor it might be loose. Or if you went to the auto parts store and asked for a 78 280Z cap, but you have a ZX distributor. A possibility, I think. I'd be surprised if that was the case. How might I tell? Link to comment https://www.classiczcars.com/forums/topic/63641-distributor-grinding/#findComment-593596 Share on other sites More sharing options...
March 3, 20205 yr Author comment_593597 On 3/2/2020 at 10:24 PM, AK260 said: Mine used to wobble as the shafts do get worn - you can see it in the video below. But it never - as far as I am aware - interfered or made grinding noises. Try to do what I did with mine in the video and see if you have more movement than I did. (And that was my old engine where the PO went wild with the blue paint!!) Mine is similar. Is that bad? Link to comment https://www.classiczcars.com/forums/topic/63641-distributor-grinding/#findComment-593597 Share on other sites More sharing options...
March 3, 20205 yr comment_593598 Yes, not good Link to comment https://www.classiczcars.com/forums/topic/63641-distributor-grinding/#findComment-593598 Share on other sites More sharing options...
March 3, 20205 yr comment_593599 On 3/3/2020 at 1:51 PM, moozieman said: Mine is similar. Is that bad? Well chap, my tuner who prepares race cars said it was, hence my path to the 123 dizzy as the play in the shaft can cause spark scatter / inaccurate timing at high engine speeds. At 6k rpm that thing is spinning 50 times per second!! The RockAuto Cardone remanufactured one I bought wasn’t much better. While the bushes can be quite easily replaced (there was a guy in the US that made them) the shaft itself gets worn. So unless you can get a new shaft, you will always have some play. I’m a geek so for me it eventually mattered. The only way to get rock solid high speed timing IMHO is crank triggered systems but it all comes down to what you want from your car and how much perfection matters ;) I’m learning the hard way that sometimes, good enough is good enough! But for me it’s more than about driving the car, it’s about giving myself “something to constantly tinker with” - read headaches!!! ;) Link to comment https://www.classiczcars.com/forums/topic/63641-distributor-grinding/#findComment-593599 Share on other sites More sharing options...
March 3, 20205 yr Author comment_593600 On 3/3/2020 at 2:12 PM, AK260 said: Well chap, my tuner who prepares race cars said it was, hence my path to the 123 dizzy as the play in the shaft can cause spark scatter / inaccurate timing at high engine speeds. At 6k rpm that thing is spinning 50 times per second!! The RockAuto Cardone remanufactured one I bought wasn’t much better. While the bushes can be quite easily replaced (there was a guy in the US that made them) the shaft itself gets worn. So unless you can get a new shaft, you will always have some play. I’m a geek so for me it eventually mattered. The only way to get rock solid high speed timing IMHO is crank triggered systems but it all comes down to what you want from your car and how much perfection matters ? I’m learning the hard way that sometimes, good enough is good enough! But for me it’s more than about driving the car, it’s about giving myself “something to constantly tinker with” - read headaches!!! ? Well for me, it's just important for it to at least run right now. And that interference is causing the engine to stall I think. Link to comment https://www.classiczcars.com/forums/topic/63641-distributor-grinding/#findComment-593600 Share on other sites More sharing options...
March 3, 20205 yr Author comment_593605 On 3/3/2020 at 1:51 PM, moozieman said: Mine is similar. Is that bad? I found that there is a certain tolerance between the rotor and each contact. I'd be surprised if it was that simple, but ill check that as well. Link to comment https://www.classiczcars.com/forums/topic/63641-distributor-grinding/#findComment-593605 Share on other sites More sharing options...
March 3, 20205 yr Author comment_593606 What is the significance of the vacuum lines leading up to the distributor? Could that pose any issues? Link to comment https://www.classiczcars.com/forums/topic/63641-distributor-grinding/#findComment-593606 Share on other sites More sharing options...
March 3, 20205 yr comment_593608 On 3/3/2020 at 1:50 PM, moozieman said: I'd be surprised if that was the case. How might I tell? Wiggle the cap. Link to comment https://www.classiczcars.com/forums/topic/63641-distributor-grinding/#findComment-593608 Share on other sites More sharing options...
