Posted March 4, 20205 yr comment_593686 I am roughly 6 months (estimated) away from putting the car in the shop for body work. In the meantime, I am stripping the car and enjoying it after getting it running right and in a reliable state. The car had a vinyl top which I removed hastily a year ago causing a majority of the adhesive to bake onto roof. I recently removed the vinyl from the hatch lid which left me in awe at the original paint. Neither here nor there... Real reason for the post - Is it worth putting some sort of rust inhibitor on the roof and affected areas between now and until it goes into the body shop? How does that affect body work in the future? For the roof, is it worth sourcing a roof for replacement instead of metalwork? Note around the front windshield pillars on either side, there are holes. Link to comment https://www.classiczcars.com/forums/topic/63650-stopping-rust-from-worsening/ Share on other sites More sharing options...
March 4, 20205 yr comment_593687 I used SEM Rust Inhibitor with good results. It'll turn whatever you put it on black but it will not rust any worse. EDIT: maybe it was "Rust Mort"? Edited March 4, 20205 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/63650-stopping-rust-from-worsening/#findComment-593687 Share on other sites More sharing options...
March 4, 20205 yr comment_593688 It's rust mort. Link to comment https://www.classiczcars.com/forums/topic/63650-stopping-rust-from-worsening/#findComment-593688 Share on other sites More sharing options...
March 4, 20205 yr comment_593690 All of that rusty metal is going to have to be replaced to repair properly. Why waste money on treating it? Spray it with some etch primer if it makes you feel better. Link to comment https://www.classiczcars.com/forums/topic/63650-stopping-rust-from-worsening/#findComment-593690 Share on other sites More sharing options...
March 4, 20205 yr comment_593697 I would treat it. I think you are likely to need a new roof skin if there is any other pitting. if not, the corners can probably be patched. Rusty metal, ultimately, has to be gotten clean and then I would treat it. Link to comment https://www.classiczcars.com/forums/topic/63650-stopping-rust-from-worsening/#findComment-593697 Share on other sites More sharing options...
March 5, 20205 yr comment_593711 http://www.corroseal.comThis is a great product. Converts rust to an inert madnetite and stops it in its tracks. I’ve used on numerous applications to include my personal vehicle. Take a look at the link. Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/63650-stopping-rust-from-worsening/#findComment-593711 Share on other sites More sharing options...
March 5, 20205 yr comment_593712 On 3/5/2020 at 2:38 AM, Av8ferg said: http://www.corroseal.com This is a great product. Converts rust to an inert madnetite and stops it in its tracks. I’ve used on numerous applications to include my personal vehicle. Take a look at the link. Sent from my iPhone using Tapatalk Sounds interesting but implying sandblasting is environmentally unfriendly is a bit of a stretch I think. Link to comment https://www.classiczcars.com/forums/topic/63650-stopping-rust-from-worsening/#findComment-593712 Share on other sites More sharing options...
March 5, 20205 yr comment_593713 On 3/5/2020 at 2:51 AM, grannyknot said: Sounds interesting but implying sandblasting is environmentally unfriendly is a bit of a stretch I think. It’s unfriendly if you are in the room with out a mask I guess. SillySent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/63650-stopping-rust-from-worsening/#findComment-593713 Share on other sites More sharing options...
March 5, 20205 yr comment_593714 On 3/5/2020 at 2:52 AM, Av8ferg said: It’s unfriendly if you are in the room with out a mask I guess. Silly Sent from my iPhone using Tapatalk Or a long sleeve shirt! ? Link to comment https://www.classiczcars.com/forums/topic/63650-stopping-rust-from-worsening/#findComment-593714 Share on other sites More sharing options...
