Brake booster?
turbo280z
That's a classic bad booster sign.  If the engine is running a bit rich the idle speed will go up.  Sounds like your engine is tuned about right so the idle speed drops.
The boosters usually go bad when the master cylinder leaks.  So watch out for brake fluid in the booster.  It will drip on to your paint and stain it.
Boosters are getting harder to find also.
Power brake exchange in San Jose California can rebuild them, I had mine done by them;
 if you end up using them have them power coat the booster, they run it through a bead blaster, it should be an additional $20.
im not sure if DIY kits are available... I wonder where PBE gets theirs....
Edited by heyitsrama
  • 1 month later...
Do you remember about how much you paid?
On 4/23/2020 at 1:42 PM, Yarb said:
Just got mine back from them. Had no idea they offered powder coating. Man.......
dont go installing it on the car without painting it, its gonna look like $^!# after it starts to rust!
Grab flat-black (at least thats what i like) 7776 rustolium and some primer. 2 coats primer, 3 coats of paint.
Might even want to grab something that's resistant to brake fluid, (caliper paint?) powder coating is not.
  • Who's Online   2 Members, 0 Anonymous, 627 Guests (See full list)
