March 20, 20205 yr comment_594846 BTW, agreed - slide the cable out at the speedo end. Most likely no need to disconnect it at the tranny. Glad that Zed Head brought that up. Link to comment https://www.classiczcars.com/forums/topic/63717-trouble-reattaching-speedometer-cable/?&page=3#findComment-594846 Share on other sites More sharing options...
March 20, 20205 yr Author Popular Post comment_594874 Thank you for the suggestion. I ended up grabbing the cable at the speedo end with a pair of vice grips and pulled it out about an inch an change. It definitely needed some force. After that I realigned the cable with the speedo and felt a much more significant "drop-in" than previous attempts. Turned the car on and it worked like a charm. Thanks again, super helpful. Link to comment https://www.classiczcars.com/forums/topic/63717-trouble-reattaching-speedometer-cable/?&page=3#findComment-594874 Share on other sites More sharing options...
October 25, 20222 yr comment_646735 On 3/20/2020 at 11:02 PM, daty240z said: Thank you for the suggestion. I ended up grabbing the cable at the speedo end with a pair of vice grips and pulled it out about an inch an change. It definitely needed some force. After that I realigned the cable with the speedo and felt a much more significant "drop-in" than previous attempts. Turned the car on and it worked like a charm. Thanks again, super helpful. Does anyone know how to reinstall correctly the speedometer and tachometer in a 1972 240z without removing the dashboard? Trying to find pictures or videos on youtube but no luck yet. Anyone? Link to comment https://www.classiczcars.com/forums/topic/63717-trouble-reattaching-speedometer-cable/?&page=3#findComment-646735 Share on other sites More sharing options...
October 25, 20222 yr comment_646746 From that thread you posted in in 2018. Seems like you should use the FSM? Edited October 25, 20222 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/63717-trouble-reattaching-speedometer-cable/?&page=3#findComment-646746 Share on other sites More sharing options...
October 25, 20222 yr comment_646747 Link to comment https://www.classiczcars.com/forums/topic/63717-trouble-reattaching-speedometer-cable/?&page=3#findComment-646747 Share on other sites More sharing options...
October 25, 20222 yr comment_646748 i need more specific details and pictures to reinstall both intruments correctly without messing anything. I have short under the dash and need to trace it. Link to comment https://www.classiczcars.com/forums/topic/63717-trouble-reattaching-speedometer-cable/?&page=3#findComment-646748 Share on other sites More sharing options...
October 25, 20222 yr comment_646749 On 10/25/2022 at 10:09 PM, jalexquijano said: i need more specific details and pictures to reinstall both intruments correctly without messing anything. I have short under the dash and need to trace it. google.com but end your search phrase with classiczcars.com. Click on images for pictures. Good luck. Link to comment https://www.classiczcars.com/forums/topic/63717-trouble-reattaching-speedometer-cable/?&page=3#findComment-646749 Share on other sites More sharing options...
