Posted March 19, 20205 yr comment_594753 So both of my door pin switches are dead. The geniuses who did the rust repair and repaint just left them in place and painted over them, and the plungers are crushed in besides... Apparently these are different between left (3-wire) and right (2-wire) sides. And the 3-wire ones seem to be NLA. Question: Is it possible to use the same switch (2-wire) on both sides? I understand this will cause issues with the seatbelt buzzer (the reason for the 3rd wire), but fastening my seatbelt is something I do instinctively anyway, so I have no qualms about disabling it if I need to. Thanks as always for any and all help. You guys are great. Link to comment https://www.classiczcars.com/forums/topic/63718-door-pin-switch-interchange-modification/ Share on other sites More sharing options...
March 19, 20205 yr comment_594760 I think the 3rd wire on the left side is for the key in the ignition buzzer when you open the door. Your choice to add a wire for this annoying little feature or just go with the 2-wire for the overhead light. Link to comment https://www.classiczcars.com/forums/topic/63718-door-pin-switch-interchange-modification/#findComment-594760 Share on other sites More sharing options...
March 19, 20205 yr Author comment_594782 3 hours ago, jfa.series1 said: I think the 3rd wire on the left side is for the key in the ignition buzzer when you open the door. Your choice to add a wire for this annoying little feature or just go with the 2-wire for the overhead light. OK thanks. I'll just order two of the right-hand ones then. The dash is currently out of the car, so it should (hopefully) be easier to disable it. I understand accessing it with the dash in place is the big challenge. Link to comment https://www.classiczcars.com/forums/topic/63718-door-pin-switch-interchange-modification/#findComment-594782 Share on other sites More sharing options...
