Posted March 25, 20205 yr comment_595359 I am in the middle of a special project on a 75 280z, part of which is a new vintage dash with retrofitting a set of Speedhut gauges. I need to find out the type and thread size of the temperature gauge sender port on the thermostat housing. The adapter in the kit is NPT thread, diameter is close but just slightly too big. Does anyone know is the port is metric or BPT? The oil sender is BPT and I re-tapped it for NPT for the new sender, it was only 1 thread off, 27 vs 28. This is the only adapter Speedhut has that appears to be close... Any ideas or insight most welcome... Link to comment https://www.classiczcars.com/forums/topic/63746-thermostat-housing-gauge-port-thread-size/ Share on other sites More sharing options...
March 25, 20205 yr comment_595363 I believe it's the same as the 240Z. Link to comment https://www.classiczcars.com/forums/topic/63746-thermostat-housing-gauge-port-thread-size/#findComment-595363 Share on other sites More sharing options...
March 25, 20205 yr comment_595365 If the Speedhut gauge sensor is 1/8 NPT https://www.amazon.com/GlowShift-Female-Sensor-Adapter-Reducer/dp/B00NWZZBS6 or https://www.amazon.com/Fitting-Female-Metric-M16X1-5-Adapter/dp/B07GRT81L7 If the Speedhut gauge sensor is 1/4 NPT https://www.amazon.com/Fitting-Female-Metric-M16X1-5-Adapter/dp/B07HGVF2PY or https://www.amazon.com/Fitting-Metric-M16X1-5-Female-Adapter/dp/B07DJZKQHY Link to comment https://www.classiczcars.com/forums/topic/63746-thermostat-housing-gauge-port-thread-size/#findComment-595365 Share on other sites More sharing options...
March 25, 20205 yr Author comment_595376 Thanks Steve! sorry I didn't search harder ... Link to comment https://www.classiczcars.com/forums/topic/63746-thermostat-housing-gauge-port-thread-size/#findComment-595376 Share on other sites More sharing options...
March 25, 20205 yr comment_595380 I just happened to remember the thread. Link to comment https://www.classiczcars.com/forums/topic/63746-thermostat-housing-gauge-port-thread-size/#findComment-595380 Share on other sites More sharing options...
