Posted April 3, 20205 yr comment_596250 Any recommendations on the correct stock starter for a 1973 240z...? Thanks...Ryals Link to comment https://www.classiczcars.com/forums/topic/63801-correct-starter/ Share on other sites More sharing options...
April 3, 20205 yr comment_596258 Any of the starters from 1970 to 1983 (ZX) will work. The ZX starters are gear reduction, higher torque. Any will bolt up and wire up and work fine. If you want it to look correct then 1970 - 1978 (?). The big ones. Link to comment https://www.classiczcars.com/forums/topic/63801-correct-starter/#findComment-596258 Share on other sites More sharing options...
April 3, 20205 yr comment_596285 4 hours ago, Tirnipgreen said: Any recommendations on the correct stock starter for a 1973 240z...? Thanks...Ryals I bought mine at Advance with a coupon code from retailmenot.com for 25% off. Buy online and pick up at the local store, if they have it in stock, 10 minutes. $20 is what I paid about 10 years ago so that says something about the reliability I guess, it still works great. Could be I'm just lucky. Nah, that can't be right. Link to comment https://www.classiczcars.com/forums/topic/63801-correct-starter/#findComment-596285 Share on other sites More sharing options...
April 3, 20205 yr comment_596292 +1 on the gear reduction starter, i bought one by accident, but it seems to start up easier. Link to comment https://www.classiczcars.com/forums/topic/63801-correct-starter/#findComment-596292 Share on other sites More sharing options...
