Good (?) examples of rust
2ManyZs
Car looks a lot better from a distance of 250ft or more... Right Ken?
The only thing keeping the car from folding up in the middle is the transmission tunnel and the roof. The floors and frame rails are gone, as well as the frame rails inside the engine compartment (someone tried to weld on C channel to keep the swaybar from falling off, it didn't work), inner hatch is rusted through etc, etc, etc.....
Sadly this one is too far gone to fix.. gonna end up in pieces this summer.
All you need is some of that super duper speed metal tape and a couple or three gallons of fiberglass reinforced Bondo and at least ONE Type R and ONE V-Tech decal and you're good to go...............ROFL
Seriously, 2mZ you're obviously wrenching too darn hard! You brute!
Don't you know you should always shoot some penetrating oil on old nuts and bolts before you go applying 200+ lbs/in of torque on them? GeeeeeeZ!
:love:
ES
Uh, er, well Enrique...
If you think about it, that bolts threads into a captured nut that is on the inside of the inner rocker... so how could you put any lube on it ,that is until the outer rocker suddenly opens up like a rotten can of tuna fish.......All the other bolts were finger tight:ermm:
Yeah, this one sat outside for years before I got it... looks like it's a goner.:disappoin
I think the last time it was registered was 91 or 92 and I didn't get it till 98:ermm:
Simple!
You did say the rocker panel was almost gone, so you shove the nozzle of the penetrating oil through one of the holes and SHOOT it at the bolt! Voila, penetrating oil from the back side!
Then, you use that metal tape to seal up the hole.......ROFL
Enrique
