Ok.  While I'm here, and speaking of fuel, my 240z has no mechanical fuel pump under the hood.  Just an added electric fuel pump back by the tank.  The previous owner has a fuel filter just prior to the electric fuel pump, and again under the hood.  What am I missing with not having that mechanical fuel pump?  When it's cold, I have to turn the key until the electric fuel pump kicks in, and count to 12, then it will usually crank.  Once it's warm, it cranks right up, although I know the carbs need some love.
An appropriately sized electric being the only pump is just fine as long as it a) can keep up with fuel demand, and b) doesn't have such a high output pressure as to overpower the float needle valves.
But about the cranking thing.... You should enough fuel in the float bowls to run the engine for maybe thirty seconds with no fuel pump at all. If your bowls are emptying out overnight or something, you need to put looking into that on your list.
You've got sight glasses on the side of your flat tops to check the bowl level.
I've checked the sight glasses.  For one of them (the rear) the fuel level is pretty much always sitting in the middle of the sight window.  The front one, OTOH, is like 20% up the window.  I figure at a minimum I need to figure out how to adjust the float on the front one.  I also need to validate that my choke is closing when i think it's closing.  Those are the two things I plan to do first, besides repair/restore my fuel tank.  Looks like people get good results with the standard POR15 repair kit?
I bought a fuel pressure regulator with a 1-6 lb range, but have not yet put it on.
Edited by Dadsun
From the looks of your engine bay it looks like it has all the dealer mods (the electric fuel pump is part of those dealer mods) attempting to eliminate the vapor locking issue (I think ceramic headers could also help with reducing the under hood temp). Are you staying stock or do you plan on any mods like air injection delete, this would happen with the ceramic headers.
To be honest, I am new to the Z car world and figuring it out as I go. I see new issues every day. I would like to stay stock where reasonable, but I also want to get this car on the road and enjoy it.  Right now, I know I have to get the gas tank taken care of, the suspension completely updated, and figure out some basic tuning of the carbs.
If you've got fuel at the middle of the rear sight glass and 20% up on the front, then you'll eventually need to take a look at the front. You've got bigger fish to fry right now though. That level discrepancy won't prevent it from starting.
When you get a chance, can you take a pic of the front side of the front carb (the sight glass side) so we can see what type of flat top you're dealing with?
2 hours ago, Captain Obvious said:
One thing I saw in your previous pics was that your "choke pull off" actuators are disconnected. I'm assuming the vacuum sources for those have been adequately capped off? If not, that's a problem.
I have no idea.  Feeling a bit overwhelmed on where to start. Here's a few pics of that front carb as requested.
Wow. OK... Well after seeing your pics, I think those are the earliest versions of the flat tops. What's your build date stamp on the door jamb plate? Early 73 probably?
From what I've heard, many of those really early ones were pulled off and replaced with later versions because of complaints. And if the customer returned again with additional complaints, then the whole rack was pulled off and replaced with round tops.
In addition to the very early nature of that set, I also see a number of little things wrong or missing.
So honestly... You guys won't hear me saying this much, but unless it's a labor of love and you just want to be able to honestly say "I'm running the original carbs that came on this car from the factory", then even I would change those out.
At a minimum, if you want to stick with flat-tops, I would change over to the later version. If you're not that interested in fighting the incoming tide of sentiment against the flat-tops, then I would switch over to a pair of round tops. Nobody would hate you for that, and in fact, most people would think it's right thing to do.
