280z - Rear Bumper Term and Door Bumper Advice
Muzez
9 hours ago, Yarb said:
 Looks like the center hole on the support brackets is Not a spot weld?
That center hole is not a spot weld. I suspect that was a locator feature. So you drilled out about the only part that is NOT holding it on.  Haha!!
Not a big deal. Stuff like that happens.
  • 11 months later...
On 1/1/2021 at 1:53 PM, Yarb said:
Jumping on this thread, Please forgive me. The first  photo of the sight shield is what I’m attempting to remove. I bought a spot weld cutter from ZCD. Drilled out the first spot weld and the bracket is still attached solid. Can anyone shed some light on this before I attempt the others? Here’s a pic of the first weld I removed and the next weld that I have not attempted.  Appreciate the guidance.   John
No apologies needed, I need to do this in a week so a big thank you!
