Gas Tank restore and POR15
Dadsun
1 hour ago, grannyknot said:
But wouldn't those nuts or bolts be coated too and stuck to something.
 Probably the bottom of the tank but that could lead to a discussion about how many is permissible all the way to why the hell take any out. They're all glued down anyway. The PO of my 260 used 3/4" (no minus) crushed rock and rolled the tank around the yard for an hour or so.
Step 1 is done. Dropped! Tank goes to the radiator shop Monday. Noted that there was no O-ring on the sending unit. Both of the big vapor hoses along the tail were dry-rotted. Anyone know of a good source for them?
