Posted May 26, 20204 yr comment_600222 A question for the guru's out there.. I have found an early type Fan, that I want to put on my Z. I've read on some online shops for Z parts that the early steel fans, also had different clutches , is this so ? Also I saw that my fan blade is missing some metal on one blade, should i have this balanced or just weld it up, smooth it out and it will be balanced enough ? Bart Link to comment https://www.classiczcars.com/forums/topic/64078-early-style-fan-and-clutch-240z/ Share on other sites More sharing options...
May 27, 20204 yr comment_600284 Could that have been from the original balancing? I do not see how it could have been done by rubbing on something. Link to comment https://www.classiczcars.com/forums/topic/64078-early-style-fan-and-clutch-240z/#findComment-600284 Share on other sites More sharing options...
May 28, 20204 yr Author comment_600335 On 5/27/2020 at 7:05 PM, jwtaylor said: Could that have been from the original balancing? I do not see how it could have been done by rubbing on something. That's my question... One of my dutch friends ( Mart ) on the forum here, he has one, but that one doesn't have it. Link to comment https://www.classiczcars.com/forums/topic/64078-early-style-fan-and-clutch-240z/#findComment-600335 Share on other sites More sharing options...
May 30, 20204 yr Author comment_600466 Found 2 different clutches like it seems ? Which one is for the steel fan, anyone ? Link to comment https://www.classiczcars.com/forums/topic/64078-early-style-fan-and-clutch-240z/#findComment-600466 Share on other sites More sharing options...
May 30, 20204 yr comment_600473 Here is one example I have. Link to comment https://www.classiczcars.com/forums/topic/64078-early-style-fan-and-clutch-240z/#findComment-600473 Share on other sites More sharing options...
June 1, 20204 yr Author comment_600599 That one looks the same like the one with the steel fan on in the picture, but the other 2 are different it seems ? The guy from the red one mailed me he said he was sure it came of a " series 1 as he calls it " Z... Interesting.. Link to comment https://www.classiczcars.com/forums/topic/64078-early-style-fan-and-clutch-240z/#findComment-600599 Share on other sites More sharing options...
June 1, 20204 yr comment_600619 Bart, the fan and clutch shown by Zkars above, is what came on my series 1 when purchased new. These fans were heavy and often caused premature failure of water pumps. It was fairly common for dealers to switch these out for the later plastic fan and clutch assembly when they became available on later Zs. I have the plastic fan assembly on my car and only put the metal fan on for shows. If you use this metal fan, I would make sure it is well balanced and has the correct resistance in the clutch. Link to comment https://www.classiczcars.com/forums/topic/64078-early-style-fan-and-clutch-240z/#findComment-600619 Share on other sites More sharing options...
June 3, 20204 yr Author comment_600731 On 6/1/2020 at 8:09 PM, AZ-240z said: Bart, the fan and clutch shown by Zkars above, is what came on my series 1 when purchased new. These fans were heavy and often caused premature failure of water pumps. It was fairly common for dealers to switch these out for the later plastic fan and clutch assembly when they became available on later Zs. I have the plastic fan assembly on my car and only put the metal fan on for shows. If you use this metal fan, I would make sure it is well balanced and has the correct resistance in the clutch. Okay. The red one could be a universal one for datsun maybe ? Link to comment https://www.classiczcars.com/forums/topic/64078-early-style-fan-and-clutch-240z/#findComment-600731 Share on other sites More sharing options...
June 6, 20204 yr Author comment_600838 To bad its a design flaw would love to have the correct metal fan on.. Will try to source the clutch and have it balanced. Keep the plastic fan on then for now... Link to comment https://www.classiczcars.com/forums/topic/64078-early-style-fan-and-clutch-240z/#findComment-600838 Share on other sites More sharing options...
June 11, 20204 yr Author comment_600976 On 5/30/2020 at 5:50 PM, zKars said: Here is one example I have. So comparing that to the other 2 pictures in my first post. This seems to be a different clutch ? Where there 2 types, or are the other ones for a colder climate maybe ? Or not specific S30 ? Maybe someone can clear this out ? Link to comment https://www.classiczcars.com/forums/topic/64078-early-style-fan-and-clutch-240z/#findComment-600976 Share on other sites More sharing options...
June 12, 20204 yr comment_601031 Pretty sure the red one and the one in the bottom photo are aftermarket. I have 2 of the original metal fans with original clutches---both are identical to the fan/clutch shown in zKars photo and as described by AZ240z. The factory service manual describes dis-assembly and replacement of the viscous fluid in the clutch. Link to comment https://www.classiczcars.com/forums/topic/64078-early-style-fan-and-clutch-240z/#findComment-601031 Share on other sites More sharing options...
June 12, 20204 yr Author comment_601034 On 6/12/2020 at 3:23 AM, Zup said: Pretty sure the red one and the one in the bottom photo are aftermarket. I have 2 of the original metal fans with original clutches---both are identical to the fan/clutch shown in zKars photo and as described by AZ240z. The factory service manual describes dis-assembly and replacement of the viscous fluid in the clutch. Ah okay. That's what I thought so also. Let's assume that for now... Link to comment https://www.classiczcars.com/forums/topic/64078-early-style-fan-and-clutch-240z/#findComment-601034 Share on other sites More sharing options...
