Posted June 5, 20204 yr comment_600815 I'll be swapping my leaking original radiator out for a shiny new Champion 2 row aluminum radiator (EC634) first thing tomorrow and I realized I don't have a drop of extra coolant around. Does anyone know from experience that this radiator will require more coolant than the stock radiator holds? Its odd I can't seem to find that info anywhere. Assuming I don't lose a drop of the almost new coolant while draining/refilling, should I 'make a trip to town' tonight to buy a jug so I'll have enough to finish the job tomorrow? Link to comment https://www.classiczcars.com/forums/topic/64115-installing-champion-2-row-radiatordoes-it-hold-more-coolant/ Share on other sites More sharing options...
June 5, 20204 yr comment_600818 If you don't need an excessive amount, you could top it up with distilled water. It won't change the freezing point significantly or compromise the anti corrosion aspects. If you need a quart or more, it's probably easier to just get a jug of prediluted Link to comment https://www.classiczcars.com/forums/topic/64115-installing-champion-2-row-radiatordoes-it-hold-more-coolant/#findComment-600818 Share on other sites More sharing options...
June 5, 20204 yr Author comment_600823 With my luck, I'd knock a jug over and have to clean up and drive to the store anyway. I'll get a gallon to have on hand. Link to comment https://www.classiczcars.com/forums/topic/64115-installing-champion-2-row-radiatordoes-it-hold-more-coolant/#findComment-600823 Share on other sites More sharing options...
June 7, 20204 yr Author comment_600856 Just as a followup for future search results, I ended up needing a few quarts more than what the original radiator held. The two-piece shroud took a little work to fit right, but installation was straightforward. Link to comment https://www.classiczcars.com/forums/topic/64115-installing-champion-2-row-radiatordoes-it-hold-more-coolant/#findComment-600856 Share on other sites More sharing options...
June 7, 20204 yr comment_600858 On 6/5/2020 at 7:19 PM, jeremy93ls said: swapping my leaking original radiator out for a shiny new Champion 2 row aluminum radiator Yeah SHINY NEW and... to me.. worthless!!.. a good radiator is made from copper NOT aluminum.. All that cheap $^!# from china (i hope yours isn't one) .. I would get me a new core and repair the old one.. (my 240z car has still the original copper core in it.. and is well over 25 years old, you don't see them in aluminum that old i think?) Fill it with proper coolant otherwise it will leak soon again. (soon is in a few years.. ? ) Link to comment https://www.classiczcars.com/forums/topic/64115-installing-champion-2-row-radiatordoes-it-hold-more-coolant/#findComment-600858 Share on other sites More sharing options...
