Posted June 13, 20204 yr comment_601099 I'm running a L28 with DCOE 42s and fuel is supplied by an engine bay mounted Spectra Sp1141. Pressure is regulated to 4psi and there's a new fuel filter before the pump. Engine compression is great. No vacuum leaks or fuel leaks to be found. Car idles and runs great, but for a hesitation from idle to acceleration. The car will pull to highway speed no problem. The mystery is that on a long sustained hill it starts popping and has a hard time going. My guess is it is going lean as it starts popping and then hesitating. As soon as the car is on level ground it's fine again. This is with 1/2 a tank of gas. Any ideas or diagnosis suggestions would be appreciated. Thank you. Sent from my SM-G950W using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/64139-car-cant-go-uphill/ Share on other sites More sharing options...
June 13, 20204 yr comment_601107 1 hour ago, jitenshakun said: The mystery is that on a long sustained hill it starts popping and has a hard time going. My guess is it is going lean as it starts popping and then hesitating. As soon as the car is on level ground it's fine again. This is with 1/2 a tank of gas. Kind of looks like you're looking for affirmation of a thought. Fill the tank and see if the problem stays. These tanks are known for pinholes in the internal outlet tube. How steep is the hill, and how long is the sustenation? Link to comment https://www.classiczcars.com/forums/topic/64139-car-cant-go-uphill/#findComment-601107 Share on other sites More sharing options...
June 13, 20204 yr Author comment_601108 The hill is 8 blocks long and it really kicks in after 4-6 blocks and lasts until I've been flat for about a block. Maybe less? 40m-50m elevation change. Sent from my SM-G950W using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/64139-car-cant-go-uphill/#findComment-601108 Share on other sites More sharing options...
June 13, 20204 yr comment_601111 It sounds like it is going lean as you say. The fact that it takes 4-6 blocks to come on and another block to recover suggests its fuel supply not jetting (as ZH says). Another test would be to stop on the hill when the problem happens and see if it struggles to idle. Link to comment https://www.classiczcars.com/forums/topic/64139-car-cant-go-uphill/#findComment-601111 Share on other sites More sharing options...
June 13, 20204 yr Author comment_601118 Lots of hills nearby so I'll try a few before I fill the tank and try again. Sent from my SM-G950W using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/64139-car-cant-go-uphill/#findComment-601118 Share on other sites More sharing options...
June 14, 20204 yr Author comment_601181 @Zed Head@jonbill I idled on a steep hill without any problems and drove up 1 block long steep hills, again with no symptoms. Same 1/2 tank of gas. My next step will be a full tank and the longer hill that's caused me problems. Sent from my SM-G950W using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/64139-car-cant-go-uphill/#findComment-601181 Share on other sites More sharing options...
June 16, 20204 yr comment_601319 Electric pumps like this work best as pushers. Try moving the pump to the rear by the tank and see if that helps. Link to comment https://www.classiczcars.com/forums/topic/64139-car-cant-go-uphill/#findComment-601319 Share on other sites More sharing options...
June 16, 20204 yr Author comment_601321 Electric pumps like this work best as pushers. Try moving the pump to the rear by the tank and see if that helps.Good tip. I'm going to do that this winter and swap out the cheap-o pump with a better unit. Sent from my SM-G950W using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/64139-car-cant-go-uphill/#findComment-601321 Share on other sites More sharing options...
