Posted June 17, 20204 yr comment_601367 Is this differential arrestor (55425-N4300) spent? It doesn’t look too bad, but it’s a little stiff and there is a tiny bit of wear near where the bolts are. Debating whether to replace it while the diff is off. Link to comment https://www.classiczcars.com/forums/topic/64151-is-this-differential-arrestor-spent/ Share on other sites More sharing options...
June 17, 20204 yr comment_601369 I've only read about them breaking for the guys that have V8's and abuse them. Link to comment https://www.classiczcars.com/forums/topic/64151-is-this-differential-arrestor-spent/#findComment-601369 Share on other sites More sharing options...
June 17, 20204 yr comment_601377 That one looks to be in excellent condition, I would say it has had an easy life so far. Link to comment https://www.classiczcars.com/forums/topic/64151-is-this-differential-arrestor-spent/#findComment-601377 Share on other sites More sharing options...
June 17, 20204 yr Author comment_601379 Thanks guys! Didn't want to throwaway good parts if not necessary. Link to comment https://www.classiczcars.com/forums/topic/64151-is-this-differential-arrestor-spent/#findComment-601379 Share on other sites More sharing options...
June 17, 20204 yr comment_601380 use it again! no problemo Link to comment https://www.classiczcars.com/forums/topic/64151-is-this-differential-arrestor-spent/#findComment-601380 Share on other sites More sharing options...
June 17, 20204 yr comment_601392 Or ditch it for a RT Mount and fix the less than optimal design. Link to comment https://www.classiczcars.com/forums/topic/64151-is-this-differential-arrestor-spent/#findComment-601392 Share on other sites More sharing options...
