Right off the bat I see a big vacuum leak. With that air filter on the valve cover you're getting unmetered air. The hose that connects the throttle body to that location is missing.
Nothing screws up the idle like a vacuum leak. As noted above, that filter on the valve cover opening is bad news, and a major vacuum leak.  It's a pain to trace and check the vacuum hoses on these engines, but they are often the problem.
Edited by Pilgrim
I had mentioned this in a previous thread, the previous owner plugged up the breather port on the block with a freeze plug. Therefore I have no pcv valve. I added that filter up top to act as my vent
1 minute ago, Zed Head said:
Did you do this test yet?  Below.  And check the vacuum line to the FPR for fuel.  It might have a blown diaphragm.
I’m confused. This test is for water temp sensor? (Which btw, my thermotime and water temp are unplugged) (it doesn’t run otherwise.)?
Yes, if the water temperature sensor is disconnected the ECU will supply maximum extra fuel.  That's probably why yours is running so rich.
If it doesn't run when it's connected it might be because it is shorted out, making the mixture as lean as possible.  Or because you have a large vacuum leak, maybe through the PCV system.
People often mess around for weeks or months trying to avoid doing the tests.  But there's a reason that Nissan created a completely separate book, very detailed, with instructions, illustrated, covering all of the years from 1975 through 1980, and published it.
How should I test for a short? It’s usually unplugged because of how rough it runs when it’s plugged in.
Edited by moozieman
