Posted June 24, 20204 yr comment_601719 My 1973 240z restoration is at a standstill. I am having a hard time dropping the big bucks on the braided hoses for the heater, radiator, power brake booster, etc. Are they really necessary for a car to be respected...? I can't seem to find the power brake booster hoses in smooth rubber like the heater and radiator ones. I found a smooth rubber reducer for left side of the engine so at least everything on that side would be smooth including the radiator hoses, if I went "cheap". I love the braided look, just amazed at the pricing...! Any comments or suggestions...? Edited June 24, 20204 yr by Tirnipgreen Had something else to add Link to comment https://www.classiczcars.com/forums/topic/64186-are-braided-hoses-necessary/ Share on other sites More sharing options...
June 24, 20204 yr comment_601720 Depends If you want to show it, then it matters. It also depends on how knowledgeable the judges are... If you want to drive it, then it doesn't. Link to comment https://www.classiczcars.com/forums/topic/64186-are-braided-hoses-necessary/#findComment-601720 Share on other sites More sharing options...
June 24, 20204 yr comment_601722 I have a mix of braided and smooth hoses in my engine bay. As to respect, there were no negative comments when my car was judged at ZCON 2015 in Memphis. My car was awarded Best Engine at that event. Its not always WHAT you do but rather HOW WELL you do it. If you elect to enter the ZCCA Stock Class, you will be expected to have every hose correct as OE. Link to comment https://www.classiczcars.com/forums/topic/64186-are-braided-hoses-necessary/#findComment-601722 Share on other sites More sharing options...
June 24, 20204 yr Author comment_601723 I thought that keeping the smooth on left side and braided on the right might be an acceptable compromise.... Link to comment https://www.classiczcars.com/forums/topic/64186-are-braided-hoses-necessary/#findComment-601723 Share on other sites More sharing options...
June 25, 20204 yr comment_601725 18 minutes ago, jfa.series1 said: I have a mix of braided and smooth hoses in my engine bay. As to respect, there were no negative comments when my car was judged at ZCON 2015 in Memphis. My car was awarded Best Engine at that event. Its not always WHAT you do but rather HOW WELL you do it. If you elect to enter the ZCCA Stock Class, you will be expected to have every hose correct as OE. Jim, My only thoughts on this are were all of the those hoses available in a braided finish at the time? We have been fortunate that many of these NLA's parts are becoming available again. Link to comment https://www.classiczcars.com/forums/topic/64186-are-braided-hoses-necessary/#findComment-601725 Share on other sites More sharing options...
June 25, 20204 yr comment_601726 Functionally, the hose braiding was supposed to provide extra 'burst' resistance. I have no idea the extent to which this is true. My best guess would be an extra 20% to 40%. Without that, the hose manufacturers wouldn't have been able to justify the extra cost to their clients, the vehicle manufacturers (notorious penny-pinchers). By the mid-1970's, however, it appears that improvements in hose materials rendered the braiding superfluous in both cost and performance. Restorers are now left with an expensive decision to make -- one that comes down to appearance and originality (it certainly has nothing to do with performance). Personally, I like the braided look -- but it's expen$ive and fragile (the OE braiding seems to have been good for about 3 or 4 years, after which it started to disintegrate). Link to comment https://www.classiczcars.com/forums/topic/64186-are-braided-hoses-necessary/#findComment-601726 Share on other sites More sharing options...
June 25, 20204 yr Author comment_601727 I think I have made my decision. Even though I bought smooth rubber heater hoses, I will buy the braided set (3 pieces) and the short reducer. I will use smooth rubber on the radiator hoses as they are much easier to replace than the heater hoses. Now another quandary...I have a new aluminum radiator ready to install and I don't mind the look. My issue is, again...originality. I have yet to find a new radiator with the little fan guard. Pulling my hair out in north Georgia...! Link to comment https://www.classiczcars.com/forums/topic/64186-are-braided-hoses-necessary/#findComment-601727 Share on other sites More sharing options...
June 25, 20204 yr Author comment_601728 BTW...Motorsports sells the braided heater hoses, but lists them for 70 - 72 only. I am switching to the 70-72 style wrap-around-the-back coolant pipe as I have gone with roundtops and the earlier crossover and intake. I assume the heater hoses will work...what say any of you...? Link to comment https://www.classiczcars.com/forums/topic/64186-are-braided-hoses-necessary/#findComment-601728 Share on other sites More sharing options...
June 25, 20204 yr comment_601734 Try Z Cars of Arizona for the radiator. It won't be cheap, I suspect. Link to comment https://www.classiczcars.com/forums/topic/64186-are-braided-hoses-necessary/#findComment-601734 Share on other sites More sharing options...
June 25, 20204 yr Author comment_601735 None of the parts houses have a radiator with the fan guard. I really don't want to solder the flap onto a new $350.00 radiator and ruin the factory finish. The radiator shop I deal with says "they paint radiators all the time". There is nothing like a factory finish. Link to comment https://www.classiczcars.com/forums/topic/64186-are-braided-hoses-necessary/#findComment-601735 Share on other sites More sharing options...
June 25, 20204 yr comment_601738 Consider locating a OE radiator and having it recored with a copper 3-row core. Most radiator shops throw on a coat of cheap black paint to cover the bare metal after the vatting. I've always requested no paint so I can strip the radiator and do my own paint. Edited June 25, 20204 yr by jfa.series1 Link to comment https://www.classiczcars.com/forums/topic/64186-are-braided-hoses-necessary/#findComment-601738 Share on other sites More sharing options...
