July 3, 20204 yr comment_602075 I don't understand the delete the smog line. Doesn't it just connect to the vapor tank. All the other connections look the same.Filler,vent,vent,vent,supply,return. Tank looks good to me. Can someone explain how to delete this line that goes to the flow valve on a 240z. Link to comment https://www.classiczcars.com/forums/topic/64210-repro-240z-fuel-tank-coming-available/?&page=2#findComment-602075 Share on other sites More sharing options...
July 3, 20204 yr comment_602078 48 minutes ago, jackmau said: I don't understand the delete the smog line. Doesn't it just connect to the vapor tank. All the other connections look the same.Filler,vent,vent,vent,supply,return. Tank looks good to me. Can someone explain how to delete this line that goes to the flow valve on a 240z. My guess is that it wasn't on the tank they had available as a model. I looked at the FSM FE section and the photos they have of their tank. I'm not sure which line is not included. Link to comment https://www.classiczcars.com/forums/topic/64210-repro-240z-fuel-tank-coming-available/?&page=2#findComment-602078 Share on other sites More sharing options...
July 4, 20204 yr comment_602104 Yes now I agree it’s not that bad a price. I wonder if the internal baffles are the same too. From their site they do some serious restorations They probably cut one up and copied it. Link to comment https://www.classiczcars.com/forums/topic/64210-repro-240z-fuel-tank-coming-available/?&page=2#findComment-602104 Share on other sites More sharing options...
July 4, 20204 yr comment_602127 Actually I am doing the reproduction. We have every type FUEL Tank as an example available. But it was a though choice! Besides we are restoring many US-cars we are also restoring and will restore some US 1969, some European cars, the last 2 came without vapor tank, so that is why we decided to produce without the vapor tank connection. Also because a lot of people in the US told me that they delete the vapor parts anyway. To be honest, the white car in the pictures with VIN HLS30-15642 is a US one, we are restoring it as it came out of the factory and for that car we added the connections to the tank after production. Link to comment https://www.classiczcars.com/forums/topic/64210-repro-240z-fuel-tank-coming-available/?&page=2#findComment-602127 Share on other sites More sharing options...
July 4, 20204 yr comment_602128 7 hours ago, SurferD said: Yes now I agree it’s not that bad a price. I wonder if the internal baffles are the same too. From their site they do some serious restorations They probably cut one up and copied it. They are a 99% copy. Link to comment https://www.classiczcars.com/forums/topic/64210-repro-240z-fuel-tank-coming-available/?&page=2#findComment-602128 Share on other sites More sharing options...
July 4, 20204 yr comment_602129 On 7/2/2020 at 9:53 PM, AK260 said: Funny this should pop up today - look what I discovered 3 hours ago while peeling back underseal and what appeared to be surface rust ... The joys of a UK car!!! At least the interior plastics are in good order And the dashes! Link to comment https://www.classiczcars.com/forums/topic/64210-repro-240z-fuel-tank-coming-available/?&page=2#findComment-602129 Share on other sites More sharing options...
July 4, 20204 yr comment_602131 This are exact pictures of the tank+ Edited July 4, 20204 yr by christoffel Link to comment https://www.classiczcars.com/forums/topic/64210-repro-240z-fuel-tank-coming-available/?&page=2#findComment-602131 Share on other sites More sharing options...
July 4, 20204 yr comment_602133 Too bad this pipe wasn't flipped 180 degrees. Then you wouldn't need that 180 degree hose to get back to the evap tank. Link to comment https://www.classiczcars.com/forums/topic/64210-repro-240z-fuel-tank-coming-available/?&page=2#findComment-602133 Share on other sites More sharing options...
July 5, 20204 yr comment_602136 4 hours ago, christoffel said: This are exact pictures of the tank+ Yep - you deleted the wrong vents . You should have kept them two and deleted the one at the back of the tank . Nissan still sells a vent hose for the front vent and the side vent doesn’t need a formed hose . The vent you kept is he hardest one to duplicate and reach . Too bad Link to comment https://www.classiczcars.com/forums/topic/64210-repro-240z-fuel-tank-coming-available/?&page=2#findComment-602136 Share on other sites More sharing options...
July 5, 20204 yr comment_602138 @w3wilkes @madkawThanks for your feedback. It is just from wich perspective you look at it. We restore several 1969 production US cars and European cars, These cars come with tanks that have the connections like the tanks we produce. Also the cars produced for the Japanese market (including the Z432), the UK , Australia and the rest of the world came in this configuraton (without the vapor connections) A lot of people I know in the US said that this configuration would fit them also, because they delete the vapor system. For the US market cars we restore to a "as it left the factory"level, after the tanks are produced, we simply ad the connections and we have the tank the car came with when new. Till now most orders came from the US, but also Japan (for a Z432) and the rest of the world. I have a 1970 919 color 240Z I use as a daly driver, and this car I run with triple Mikuni's so I don't need the emission and vapor stuff at all on this car. Edited July 5, 20204 yr by christoffel Link to comment https://www.classiczcars.com/forums/topic/64210-repro-240z-fuel-tank-coming-available/?&page=2#findComment-602138 Share on other sites More sharing options...
July 5, 20204 yr comment_602140 You didn’t completely delete the vapor system because you left one of the vent tubes . The vent tube you left is the hardest to connect . Im also not sure how you delete all the vents and the fuel tank can properly operate and breathe. There has been members here that have deleted the vents and have had fuel cavitation from lack of air to vent the tank . One vent line might be enough and I think the OEM system seems too much . I also am glad you are making these and I am not nit picking your effort . I just did a tank vapor system with all new hoses and the one in the top back is the worse to do . That why I wish you left the other two . Good luck and thanks for your efforts Link to comment https://www.classiczcars.com/forums/topic/64210-repro-240z-fuel-tank-coming-available/?&page=2#findComment-602140 Share on other sites More sharing options...
July 5, 20204 yr comment_602141 +1 for Flipping the rear vent tube. This would make replacement of that hose a lot easier. Great job though and the price seems very reasonable to me. Link to comment https://www.classiczcars.com/forums/topic/64210-repro-240z-fuel-tank-coming-available/?&page=2#findComment-602141 Share on other sites More sharing options...
