July 20, 20204 yr comment_603115 This recent thread:https://www.classiczcars.com/forums/topic/64260-240z-hls-30-42277-restauration-colombia-southamerica/?do=findComment&comment=603098 Includes some pics of what looks like the same transmission: Kinda dark inside the bell housing to get a real good look at the pivot ball post, but maybe @Mazinga Z would be willing to take a closer pic for you. Link to comment https://www.classiczcars.com/forums/topic/64212-clutch-fork-throw/?&page=9#findComment-603115 Share on other sites More sharing options...
July 20, 20204 yr comment_603123 Link to comment https://www.classiczcars.com/forums/topic/64212-clutch-fork-throw/?&page=9#findComment-603123 Share on other sites More sharing options...
July 20, 20204 yr comment_603137 For easy reference. rcv's picture from earlier. Link to comment https://www.classiczcars.com/forums/topic/64212-clutch-fork-throw/?&page=9#findComment-603137 Share on other sites More sharing options...
July 20, 20204 yr Author comment_603148 On 7/20/2020 at 5:03 AM, 240dkw said: 31 with washer and 28.4 without Ok, so that's very interesting - your pivot is only ~2mm taller than mine, however you measure only 105mm from the bellhousing face to the pivot, whereas I have 116mm. I wonder where those extra 9mm are coming from. Looking at the two pictures inside our bellhousings, the transmissions certainly look identical. Link to comment https://www.classiczcars.com/forums/topic/64212-clutch-fork-throw/?&page=9#findComment-603148 Share on other sites More sharing options...
July 20, 20204 yr comment_603149 On 7/18/2020 at 7:07 PM, rcv said: The other measurements would tell something, if @240dkw has the time. Link to comment https://www.classiczcars.com/forums/topic/64212-clutch-fork-throw/?&page=9#findComment-603149 Share on other sites More sharing options...
July 21, 20204 yr comment_603154 Rcv — 150. Mine - 153 73. 74 20. 18 25. 26 as well, I get 136 to the flat that the pivot screws into, Hope this helps. Edited July 21, 20204 yr by 240dkw Link to comment https://www.classiczcars.com/forums/topic/64212-clutch-fork-throw/?&page=9#findComment-603154 Share on other sites More sharing options...
July 25, 20204 yr Author comment_603331 On 7/21/2020 at 1:43 AM, 240dkw said: I get 136 to the flat that the pivot screws into I just pulled off my transmission again to measure this, and I get the same as you - ~135mm to the flat. I remeasured the distance from the transmission face to the pivot, and I now get 105mm with my extra 4mm of washers. I must have made a measuring mistake the first time. I’m uploading my amended drawing below. Link to comment https://www.classiczcars.com/forums/topic/64212-clutch-fork-throw/?&page=9#findComment-603331 Share on other sites More sharing options...
July 26, 20204 yr comment_603352 Well that is good that you do not have a odd transmission, but still sucks as to what is the answer your problem. Link to comment https://www.classiczcars.com/forums/topic/64212-clutch-fork-throw/?&page=9#findComment-603352 Share on other sites More sharing options...
July 26, 20204 yr Author comment_603353 Yeah, I agree. I can't really wrap my head around our disparities in measurements. We seem to get the distance to the pivot mounting flat, and our pivots seem to be the same dimensions. However, we get different measurements from the bellhousing face to the pivot even when I take my extra washers into account. You don't happen to have the original pressure plate that came with the car do you? My theory is that the one that goes with the 71A transmission is actually taller than the one that goes with the 71B. I'm getting pretty close to putting this into the cold case files anyway. I did take some 3d scans of the inside of the bellhousing just in case I want to reference it later. You can check out a preview here: https://platform.standardcyborg.com/sharescan/igyMyZc7. I took a couple that I'll align and mesh together at some point, but just let me know if anyone wants the raw data. Link to comment https://www.classiczcars.com/forums/topic/64212-clutch-fork-throw/?&page=9#findComment-603353 Share on other sites More sharing options...
July 26, 20204 yr comment_603363 Sorry no I tossed it when I replaced it with the exedy one. I had no problems installing it. Link to comment https://www.classiczcars.com/forums/topic/64212-clutch-fork-throw/?&page=9#findComment-603363 Share on other sites More sharing options...
September 6, 20204 yr Author comment_605403 Just a quick update for anyone else who runs across this: The engine/transmission is now in the car, and even though it's not running yet I did some test runs by pushing my car down my driveway, putting it into gear and then slowly releasing the clutch. Things feel pretty good, so I'm going to call this a success so far. I'll post a final update once the car is driving. Link to comment https://www.classiczcars.com/forums/topic/64212-clutch-fork-throw/?&page=9#findComment-605403 Share on other sites More sharing options...
February 28, 20214 yr comment_616805 On 7/3/2020 at 9:12 PM, rcv said: Yeah looks like I read closer to 150mm. Possibly this pressure plate isn’t right for my setup? I could have sworn I checked the height and it was the same as the old one. I’ll pull the transmission off and check again. I’m really hoping I don’t need to get another pressure plate as I already had this one balanced with my flywheel. I seem to have exactly the same issue Link to comment https://www.classiczcars.com/forums/topic/64212-clutch-fork-throw/?&page=9#findComment-616805 Share on other sites More sharing options...
