Current collar:
1.506" ( 38.25 mm) OA height
1.091" ( 27.7 mm) from the top to the milled flat
So smaller than all 4 in post #130
If I went to the ZX collar I would theoretically gain 15mm. Making my stack up about 92mm. Does anybody have one?
@Terrapin Z?
34 minutes ago, Patcon said:
Current collar:
@Terrapin Z?
There are two collars for the ZX one fits the 2+0 NA with the 225mm clutch like all the280Z and early 280ZX, The other fits the later 2+2 ZX NA, and the Turbo with the 240MM clutch.
Edited by Terrapin Z
clarification
I have bought a 240mm clutch kit. I'm not sure of the difference in the collars.
I am headed to a Z car show tomorrow morning. I'll see what I have that might help you out when I get home.  There is a different one for the 240mm
I bought my transmission from a 2+2 with the 240mm clutch. I used the collar from that car but bought a new 240mm clutch and aluminum flywheel.  It works fine using the stock 240 master/slave and fork.
1 hour ago, Terrapin Z said:
It had been an odd weekend. One of those “if it can go wrong it will”.
i have a bin of collars that all have bearings on them.
did you figure an overall measurement needed?
I understand.
I have a new part on the way. Let me lay my hands on that first
22 hours ago, Patcon said:
I understand.
I to understand, apologies for the delay. I hope the one you have inbound works out for you. If not let me know. I should have something that might work.
That's great. I was just searching around on rockauto and they showed a part being available so I took a chance. We'll see what I get.
Your delay wasn't a problem. I was just being a little random...
So I received the new collar yesterday
I ordered a different one but it was out of stock. I selected another product and Rockauto shipped it for the same price as the cheaper one. Which I thought was cool!
It looks to be about 10mm taller. I might go over to Cody's tomorrow and check out the total stack height
