Posted June 2, 200321 yr comment_39479 Not sure where I should have posted this, but you can be guaranteed that it ended up in the wrong spot. I am after one of two things, a few detailed photos of a battery hold down bracket for the 240Z, or a cheap one that someone is willing to sell me. Prefer one in Australia, but if its free, I guess the shipping would beworth while. Looked everywhere and can't find one here.Cheers Chris Link to comment https://www.classiczcars.com/forums/topic/6425-battery-hold-down/ Share on other sites More sharing options...
June 2, 200321 yr comment_39480 If you can't find one Chris I'm sure you'd be able to make one. At least it'll be brand new this way. Link to comment https://www.classiczcars.com/forums/topic/6425-battery-hold-down/#findComment-39480 Share on other sites More sharing options...
June 2, 200321 yr comment_39481 but here in the states you can go to your local parts store and get yourself one that is basically a universal hold down kit for 5 dollars usd.if you are looking for an original hmm i wouldnt know where to look for one Link to comment https://www.classiczcars.com/forums/topic/6425-battery-hold-down/#findComment-39481 Share on other sites More sharing options...
June 2, 200321 yr Author comment_39482 Making one is not a problem, and it is what I intended to do originally, however I have not been able to find the dimensions, a part number etc, but not the dimensions of the steel and the actual overall size it should be. Even if someone just goes and measures theirs and grabs a photo of the part where it hooks into the firewall, it should be more than sufficient to create a pretty close replica.Cheers Chris Link to comment https://www.classiczcars.com/forums/topic/6425-battery-hold-down/#findComment-39482 Share on other sites More sharing options...
June 2, 200321 yr comment_39484 This stuff is always on ebay or at MSA or VB. Cost is always the limiting factor. I use a really nice bungee. Adds color to the engine bay. Original hold down wouldn't fit battery. Would have limited my choice of batteries. Link to comment https://www.classiczcars.com/forums/topic/6425-battery-hold-down/#findComment-39484 Share on other sites More sharing options...
June 2, 200321 yr comment_39504 I'd highly recommend getting the VB equipment. Getting the frame and everything would run you about $30 USD, but you get security and peace of mind. I had my own makeshift setup when the old hold down came apart on me, but you make a couple jarring sharp turns, and you could end up loosening something up. Its especially a problem in a 240, where the engine bay has soooo much free room. I've had my battery almost completely slide off the tray, so its something to watch out for. Link to comment https://www.classiczcars.com/forums/topic/6425-battery-hold-down/#findComment-39504 Share on other sites More sharing options...
June 2, 200321 yr comment_39507 You could always try a bungie chord. I had an old Honda that I autoxed and having a bungie holding the battery in place it still passed tech inspection for autox. Super easy and cheap way to go but not really the best solution...just an idea. Link to comment https://www.classiczcars.com/forums/topic/6425-battery-hold-down/#findComment-39507 Share on other sites More sharing options...
July 5, 200321 yr comment_42913 Did you call your local Nissan Dealer's Parts Dept? They were available here and very inexpensive (as 240-Z parts go)... I can't believe they couldn't getone for you. (would save shipping costs if they could ). If you don't have it, you could order the original battery tray that helps keep acid off the frame railsalsoJust measure the top of a Group 24 Battery - that's what the original holddown's - held down.Carl B.send me an e-mail and I'll send you a picture..beck@becksystems.com Link to comment https://www.classiczcars.com/forums/topic/6425-battery-hold-down/#findComment-42913 Share on other sites More sharing options...
July 7, 200321 yr comment_42988 Official Nissan Part Numbers:Battery Tray 24428-N3600 Battery Frame 24420-E4600Frame Hold-down bolt 24425-89903Call your nearest Nissan dealership and quote the numbers above and they should be able to help you out.RegardsJoseph Link to comment https://www.classiczcars.com/forums/topic/6425-battery-hold-down/#findComment-42988 Share on other sites More sharing options...
