Posted July 18, 20204 yr comment_602980 OK Gang; I have power (with key on to the #1 pin of my ECU. I have a new engine with zero miles on it. It ran for about 4 minutes & then died, never to restart. I have fuel, spark, and have swapped out the Transistor box,coil,ECU,thermo time switch,pickup eye (in distributor), and checked the continuity of the negative side of the coil to the ECU. This shows a 5.9 voltage & the rest of the active terminals show a 3.89 Voltage.There is juice at both sides of the injectors. I still have no NOID light blinking, so now what??? Edited July 18, 20204 yr by kelley0352@att.net clarification Link to comment https://www.classiczcars.com/forums/topic/64256-1978-280-z-automatic-tranny-with-no-noid-light-blinking-at-injectors/ Share on other sites More sharing options...
July 18, 20204 yr comment_602985 21 minutes ago, kelley0352@att.net said: checked the continuity of the negative side of the coil to the ECU. This shows a 5.9 voltage & the rest of the active terminals show a 3.89 Voltage.There is juice at both sides of the injectors. I still have no NOID light blinking, so now what??? It seems like you might have a short in your ignition system. With the key on, engine not running, you should see battery voltage at the coil. There will be no current flowing. It might be that your ignition module is bad. Try using starting fluid to see if the engine will run. If it does you have spark. Did you mean 5.9 volts or 5.9 ohms? Aside from that, you'll still be better off to write down everything that about the car, like when it last ran right, and how long it's been sitting, and all of the measurements you've taken, making sure that they are correct. Ohms, volts, etc. Link to comment https://www.classiczcars.com/forums/topic/64256-1978-280-z-automatic-tranny-with-no-noid-light-blinking-at-injectors/#findComment-602985 Share on other sites More sharing options...
July 18, 20204 yr Author comment_602988 Ohms, sorry. This car was running with a brand new engine, (both cars are new engines) 3-4 weeks ago. I put my red one on blocks & rebuilt the entire car in 18 months. Struts, brakes, motor, mounts, Cat, 3 row radiator, & installed Michelin Radials. Then I parked my running white Z and pulled the running motor out & had it rebuilt. Had it fired up & running 3 - 4 weeks ago. It started to bog down & died, never to restart to date. Link to comment https://www.classiczcars.com/forums/topic/64256-1978-280-z-automatic-tranny-with-no-noid-light-blinking-at-injectors/#findComment-602988 Share on other sites More sharing options...
July 19, 20204 yr comment_602998 Starting fluid... Link to comment https://www.classiczcars.com/forums/topic/64256-1978-280-z-automatic-tranny-with-no-noid-light-blinking-at-injectors/#findComment-602998 Share on other sites More sharing options...
July 19, 20204 yr Author comment_603024 Zed Head are you still there? OK Anyone got some advice 4 me? I was working on my red 280 Z {1978 5} speed when I touched a test light to the neg side of my coil, it knocked out my injector power so I guessed that the problem was in the ECU so I swapped it out. Will that fix the problem or did something else short out ? Edited July 19, 20204 yr by kelley0352@att.net Link to comment https://www.classiczcars.com/forums/topic/64256-1978-280-z-automatic-tranny-with-no-noid-light-blinking-at-injectors/#findComment-603024 Share on other sites More sharing options...
July 19, 20204 yr comment_603025 4 hours ago, Zed Head said: Starting fluid... Did it start when you tried starting fluid? Link to comment https://www.classiczcars.com/forums/topic/64256-1978-280-z-automatic-tranny-with-no-noid-light-blinking-at-injectors/#findComment-603025 Share on other sites More sharing options...
July 19, 20204 yr Author comment_603026 2 hours ago, Zed Head said: Did it start when you tried starting fluid? no and I used gasoline & didn't even sputter or gough but it has great spark! so what is it if not the ECU ? I have Never seen an engine that has fuel & spark that wouldn't at least cough & sputter but I got nothing from it! so what shut down on me ? Now both of my Z cars have the same problem & it is not the ECU........ Another problem is the Red Z that I put the tester to & it killed the injectors. I swapped out the ecu because I thought it had damaged it somehow & reinstalled another ecu. shouldn't that fix the problem? or did that action short out something else somewhere else ? . OK OK OK!!! I primed it with Gasoline & it did not even sputter but there is Great Spark @ the coil & at the plugs! Edited July 19, 20204 yr by kelley0352@att.net clarification Link to comment https://www.classiczcars.com/forums/topic/64256-1978-280-z-automatic-tranny-with-no-noid-light-blinking-at-injectors/#findComment-603026 Share on other sites More sharing options...
July 19, 20204 yr Author comment_603027 I primed it with Gasoline & it did not even sputter but there is Great Spark @ the coil & at the plugs! Link to comment https://www.classiczcars.com/forums/topic/64256-1978-280-z-automatic-tranny-with-no-noid-light-blinking-at-injectors/#findComment-603027 Share on other sites More sharing options...
July 19, 20204 yr comment_603035 7 hours ago, kelley0352@att.net said: I primed it with Gasoline & it did not even sputter but there is Great Spark @ the coil & at the plugs! If you have great spark and you manually added fuel it should run. I find adding fuel can be hit or miss. Liquid fuel is not combustible. I have better success with Ether Link to comment https://www.classiczcars.com/forums/topic/64256-1978-280-z-automatic-tranny-with-no-noid-light-blinking-at-injectors/#findComment-603035 Share on other sites More sharing options...
July 19, 20204 yr Author comment_603038 9 hours ago, Zed Head said: Did it start when you tried starting fluid? NO! Not even a sputter or a cough. I have never seen an engine that would not fire with spark & fuel, so what is it? I know it is not the ECU Link to comment https://www.classiczcars.com/forums/topic/64256-1978-280-z-automatic-tranny-with-no-noid-light-blinking-at-injectors/#findComment-603038 Share on other sites More sharing options...
July 19, 20204 yr Author comment_603041 no there is something else wrong. this is a brand new engine Edited July 19, 20204 yr by kelley0352@att.net Link to comment https://www.classiczcars.com/forums/topic/64256-1978-280-z-automatic-tranny-with-no-noid-light-blinking-at-injectors/#findComment-603041 Share on other sites More sharing options...
July 19, 20204 yr comment_603054 Remove a spark plug and post a picture of it. Link to comment https://www.classiczcars.com/forums/topic/64256-1978-280-z-automatic-tranny-with-no-noid-light-blinking-at-injectors/#findComment-603054 Share on other sites More sharing options...
