July 19, 20204 yr Author comment_603059 I know how to take a picture of it (it seems to be carboned up) but I don't know how to post the picture from my PC to the Classic forum... Link to comment https://www.classiczcars.com/forums/topic/64256-1978-280-z-automatic-tranny-with-no-noid-light-blinking-at-injectors/?&page=2#findComment-603059 Share on other sites More sharing options...
July 19, 20204 yr Author comment_603063 1 hour ago, Zed Head said: Remove a spark plug and post a picture of it. Well Ed I got the red one running by pulling the plugs & priming each cylinder, once it fired up I blew it out on the freeway. (carboned up from cranking it) I have never seen 6 plugs/cylinders) go bad all at once. I will try the same thing on my white Z. Thank you for staying with me on this. It filled me with anxiety & I bothered 3 of the best mechanics in central calif. over this. If You have a regular email I'll send you some pictures, my Z's ar really clean & I drive them up bumpy dirt roads in the sierras all the time. I am @kelley0352@att.net Link to comment https://www.classiczcars.com/forums/topic/64256-1978-280-z-automatic-tranny-with-no-noid-light-blinking-at-injectors/?&page=2#findComment-603063 Share on other sites More sharing options...
July 19, 20204 yr comment_603067 You can post a picture from the site's response page. Link to comment https://www.classiczcars.com/forums/topic/64256-1978-280-z-automatic-tranny-with-no-noid-light-blinking-at-injectors/?&page=2#findComment-603067 Share on other sites More sharing options...
July 19, 20204 yr Author comment_603073 Under what ? I don't see a paperclip anywhere. I pulled all the plugs out of my white Z , cleaned them, primed the cylinder, replaced them & still won't start but it does kick a little like it is trying to start Edited July 19, 20204 yr by kelley0352@att.net clarification Link to comment https://www.classiczcars.com/forums/topic/64256-1978-280-z-automatic-tranny-with-no-noid-light-blinking-at-injectors/?&page=2#findComment-603073 Share on other sites More sharing options...
July 19, 20204 yr comment_603074 Click on choose files underneath the response box. A new menu will open that lets you pick files from your computer or phone. When you pick them they will be put in to your response. Link to comment https://www.classiczcars.com/forums/topic/64256-1978-280-z-automatic-tranny-with-no-noid-light-blinking-at-injectors/?&page=2#findComment-603074 Share on other sites More sharing options...
July 19, 20204 yr Author comment_603078 Still have not found a response box. Still having the same problem with the white Z with zero miles on it that ran for 3-4 minutes then died never to restart. Pulled all the plugs, (they were carboned up also) buffed them off because they are new also, shot gas into the cylinder & cranked it over, got nothing. I shot either into my white Z & still got nothing, has 12v @ injector plug. it is 101 degrees here now so I think i am done for the day. Edited July 19, 20204 yr by kelley0352@att.net Link to comment https://www.classiczcars.com/forums/topic/64256-1978-280-z-automatic-tranny-with-no-noid-light-blinking-at-injectors/?&page=2#findComment-603078 Share on other sites More sharing options...
July 19, 20204 yr comment_603079 It's the thing you write your words in. Link to comment https://www.classiczcars.com/forums/topic/64256-1978-280-z-automatic-tranny-with-no-noid-light-blinking-at-injectors/?&page=2#findComment-603079 Share on other sites More sharing options...
July 19, 20204 yr comment_603080 It's below my post here. "Reply to this topic"  Link to comment https://www.classiczcars.com/forums/topic/64256-1978-280-z-automatic-tranny-with-no-noid-light-blinking-at-injectors/?&page=2#findComment-603080 Share on other sites More sharing options...
