So.....normally, you jack up the rear end and when you rotate a tire one way, the other tire rotates the opposite way, except LSD's which rotate together blah, blah, blah.............What does it mean if the other tire DOESN'T rotate? Is the rear end horribly worn? I tried both sides, and the input shaft rotates along with each side, and the opposite end nudges a bit in the opposite direction, but doesn't rotate at all. Yes, the brakes were off...completely off: disks, calipers, everything. Nothing but raw shafts.
steve77
https://www.classiczcars.com/forums/topic/6426-diffy-rotation/
Does your driveshaft rotate when you rotate the wheel, while the other wheel is not rotating? If it does, you are probably OK. It's probably normal wear. Speaking of a Diffy, have you seen the new pic post on the Z babe gallery? Now that's a Diffy!!!
Good, because it's a 390 I might want to use someday. What happens if you put a 390 behind a 240 4-speed? Hmmmm...I am assuming the ZX 5-speed normally in front of the 390 is a bit taller. YES, I know where all the tranny cal-q-laters and all that is...just thinking out loud. Thanks for all the input.
steve77
