August 12, 20204 yr comment_604110 Bumping up over the page full of images... Has Dr. Dave pulled that plastic piece out yet? He already drilled a bigger hole in it. You have a better movie memory than I do DWM. I saw all of the talk about fluids and thought of Dr. Strangelove. Couldn't pick the right quote though... Link to comment https://www.classiczcars.com/forums/topic/64275-perplexing-fuel-light-malfunction/?&page=18#findComment-604110 Share on other sites More sharing options...
August 12, 20204 yr Author comment_604113 On 8/12/2020 at 4:24 AM, Zed Head said: Bumping up over the page full of images... Has Dr. Dave pulled that plastic piece out yet? He already drilled a bigger hole in it. You have a better movie memory than I do DWM. I saw all of the talk about fluids and thought of Dr. Strangelove. Couldn't pick the right quote though...I tried pulling the cap off and applied quite a bit of force to it but it didn't budge. It's wedged into the can very solidly, much more than the stock Datsun piece. That's when I decided to enlarge the hole and leave it at that. Sent from my SM-N950U using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/64275-perplexing-fuel-light-malfunction/?&page=18#findComment-604113 Share on other sites More sharing options...
August 12, 20204 yr comment_604115 Turned on the Hoover for you: 2 Repairs using alternate thermister https://www.goldwingfacts.com/threads/1100-low-fuel-light-mod.561082/ https://goldwingdocs.com/forum/viewtopic.php?t=35157 Mod to float type: https://goldwingdocs.com/forum/viewtopic.php?t=11167 Possible Substitute Sensor https://secure.cougarpartscatalog.com/fm-ef008a.html?sessionthemeid=26 btw thermisters are used in synths to stabilize VCO's! Edited August 12, 20204 yr by 240260280 Link to comment https://www.classiczcars.com/forums/topic/64275-perplexing-fuel-light-malfunction/?&page=18#findComment-604115 Share on other sites More sharing options...
August 15, 20204 yr comment_604257 Anyone ask what bulb zcd used to make it work? I would assume that they tested this out before selling right? Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/64275-perplexing-fuel-light-malfunction/?&page=18#findComment-604257 Share on other sites More sharing options...
August 15, 20204 yr Author comment_604258 On 8/15/2020 at 4:44 PM, AZDatsun said: Anyone ask what bulb zcd used to make it work? I would assume that they tested this out before selling right? Sent from my iPhone using TapatalkHaven't asked but we can assume that the ZCD sender was designed to work with the original bulb since it's intended to replace the original sending unit.Remember, according to ZCD their unit has worked well (to their knowledge) and nobody else on this forum has joined this discussion asserting they've had the same issue. Maybe it's a small batch of senders with an incorrect thermistor, or maybe it's my bad luck that I received 2 units with the same malfunction. I will contact them once again when we reach our conclusions with information that should be beneficial for their product development. After all, the intention is to help companies like ZCD in their mission to provide Z owners with high quality spare parts when needed. Sent from my SM-N950U using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/64275-perplexing-fuel-light-malfunction/?&page=18#findComment-604258 Share on other sites More sharing options...
August 15, 20204 yr comment_604272 For what it's worth I got the same part from ZCD and had the same issue. They sent me out a replacement which I will swap in eventually. I also remember that this problem didn't start immediately - it manifested after a few months... Edited August 15, 20204 yr by chaseincats Link to comment https://www.classiczcars.com/forums/topic/64275-perplexing-fuel-light-malfunction/?&page=18#findComment-604272 Share on other sites More sharing options...
August 15, 20204 yr comment_604275 On 7/23/2020 at 5:38 PM, dmorales-bello said: I contacted Scott at Z Car Depot and he said he hadn't had that malfunction reported before and he immediately sent out another sender. Amazing customer service!! Huh... Link to comment https://www.classiczcars.com/forums/topic/64275-perplexing-fuel-light-malfunction/?&page=18#findComment-604275 Share on other sites More sharing options...
August 15, 20204 yr Author comment_604277 On 8/15/2020 at 8:25 PM, Zed Head said: Huh...Huh, huh!We have an apparent trend... Sent from my SM-N950U using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/64275-perplexing-fuel-light-malfunction/?&page=18#findComment-604277 Share on other sites More sharing options...
August 16, 20204 yr comment_604288 On 8/15/2020 at 7:43 PM, chaseincats said: For what it's worth I got the same part from ZCD and had the same issue. They sent me out a replacement which I will swap in eventually. I also remember that this problem didn't start immediately - it manifested after a few months... Could it be a cold gasoline/warm gasoline situation? Was it cold out when it worked right and went bad when the weather changed? Link to comment https://www.classiczcars.com/forums/topic/64275-perplexing-fuel-light-malfunction/?&page=18#findComment-604288 Share on other sites More sharing options...
August 16, 20204 yr comment_604297 On 8/16/2020 at 12:31 AM, Zed Head said: Could it be a cold gasoline/warm gasoline situation? Was it cold out when it worked right and went bad when the weather changed? I don't believe so because here in TX it's been hot since before I installed it but an interesting theory anyhow. Link to comment https://www.classiczcars.com/forums/topic/64275-perplexing-fuel-light-malfunction/?&page=18#findComment-604297 Share on other sites More sharing options...
August 16, 20204 yr comment_604312 I suspect it's just designed too close to the hairy edge of working (or not working). The one or two prototypes probably worked great on the bench, but now that there are more of them out in the field, the parts tolerances variability and operating environment are having unforeseen results. Not that I've ever had that happen to me or anything........ Link to comment https://www.classiczcars.com/forums/topic/64275-perplexing-fuel-light-malfunction/?&page=18#findComment-604312 Share on other sites More sharing options...
August 16, 20204 yr comment_604319 I have the zcd sender but I have too much gas right now to test about how much before the empty line will it start to glow? If I just lift the sender up out of the tank the light should come on right? Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/64275-perplexing-fuel-light-malfunction/?&page=18#findComment-604319 Share on other sites More sharing options...
