Posted July 25, 20204 yr comment_603320 Rebuilding a smog pump. Wanting to confirm details. The back casting of the pump looks as if it was black. The pulley, mounting bracket, and adjustment arm Datsun engine blue. Can someone confirm this for me. Also this is all of the parts getting ready for paint, and plating next a set of hoses. I will post more as this project progresses. Thanks PS I am still looking for a confirmed source for the Datsun blue engine paint, not something close but the real deal. If you look closely at the photo I have not blasted the adjustment arm yet, it has a good clean coat of the original paint for comparison. Link to comment https://www.classiczcars.com/forums/topic/64278-restoration-of-smog-pump-original-paint/ Share on other sites More sharing options...
July 25, 20204 yr comment_603324 Sounds right to me Jerry. That would match what I have observed and done on my resto's. Mike McGinnis would have the ZCCA correct Datsun blue. (middle of page) Ask Mike for confirmation of the smog pump back plate color when you call him with your order. http://www.zzxdatsun.com/catRequests.php Link to comment https://www.classiczcars.com/forums/topic/64278-restoration-of-smog-pump-original-paint/#findComment-603324 Share on other sites More sharing options...
July 25, 20204 yr comment_603327 +1 on getting the correct Datsun blue from Mike McGinnis, ZCCA approved! Link to comment https://www.classiczcars.com/forums/topic/64278-restoration-of-smog-pump-original-paint/#findComment-603327 Share on other sites More sharing options...
July 25, 20204 yr comment_603334 + 2 on all of the above. This is mine which must have been judged to be correct at the 2012 ZCON. Link to comment https://www.classiczcars.com/forums/topic/64278-restoration-of-smog-pump-original-paint/#findComment-603334 Share on other sites More sharing options...
July 25, 20204 yr Author comment_603335 On 7/25/2020 at 6:50 PM, AZ-240z said: + 2 on all of the above. This is mine which must have been judged to be correct at the 2012 ZCON. Is the back cast iron black or natural cast? Link to comment https://www.classiczcars.com/forums/topic/64278-restoration-of-smog-pump-original-paint/#findComment-603335 Share on other sites More sharing options...
July 25, 20204 yr comment_603337 Cast iron black, Jerry. Link to comment https://www.classiczcars.com/forums/topic/64278-restoration-of-smog-pump-original-paint/#findComment-603337 Share on other sites More sharing options...
July 25, 20204 yr comment_603338 This is great! I just bought one that will need to be restored. Supposed to arrive Monday. Link to comment https://www.classiczcars.com/forums/topic/64278-restoration-of-smog-pump-original-paint/#findComment-603338 Share on other sites More sharing options...
July 26, 20204 yr comment_603355 NOS repair kit I hoovered somewhere. Plating and colours may be helpful to this thread. Link to comment https://www.classiczcars.com/forums/topic/64278-restoration-of-smog-pump-original-paint/#findComment-603355 Share on other sites More sharing options...
