Posted August 9, 20204 yr comment_603990 So, I got a new Delphi mechanical fuel pump, and finally installed it. Drove about 20 miles, and the car died. Checked every thing, and found that there was no fuel. I put the old fuel pump in, which has been in the car for years, and the car started up after the carbs got fuel. Checked the pump, and it looks identical to the GMB fuel pump, and the Delphi looks identical except for the Delphi written on it. I checked to see if there was any suction after removing it, and there was none. Just a heads up, kinda of a bummer........ Link to comment https://www.classiczcars.com/forums/topic/64318-new-fuel-pump-failure/ Share on other sites More sharing options...
August 9, 20204 yr comment_603992 That's why i bought the last 3 pumps here in the netherlands in the original box.. many years ago.. i hate those junk fake parts (what you get on ebay..) most are cheap but also worth nothing. Link to comment https://www.classiczcars.com/forums/topic/64318-new-fuel-pump-failure/#findComment-603992 Share on other sites More sharing options...
August 9, 20204 yr comment_604010 https://www.classiczcars.com/forums/topic/64113-weakness-revealed-in-the-gmb-and-spectra-mechanic-fuel-pumps/ Link to comment https://www.classiczcars.com/forums/topic/64318-new-fuel-pump-failure/#findComment-604010 Share on other sites More sharing options...
