Phengvang18 Posted August 11, 2020 Share #1 Posted August 11, 2020 (edited) Hello, so I was cleaning my turn signal switch and happen to break the circuit board as I was trying to pry it open to clean the contacts. is there any way I can repair this? Any type of conductive adhesive I can apply? What type of services could be able to restore this piece? I would gladly buy this piece as well if anyone is selling it! I have attached a few photos here as well. Thanks! Edited August 11, 2020 by Phengvang18 Link to comment Share on other sites More sharing options...
Zed Head Posted August 11, 2020 Share #2 Posted August 11, 2020 You might be able to glue a stiff backing material on to it to get the pieces together and aligned then repaint the circuits using conductive paint. Looks like a tough project though. https://www.amazon.com/Silver-Conductive-Adhesive-Electronics-Circuit/dp/B086VMYK4Z https://circuitscribe.com/products/10g-brush-screenprinting-conductive-silver-ink-beta Link to comment Share on other sites More sharing options...
7tooZ Posted August 11, 2020 Share #3 Posted August 11, 2020 I think I have one I can send you? what year was your can manufactured? Link to comment Share on other sites More sharing options...
SteveJ Posted August 11, 2020 Share #4 Posted August 11, 2020 The switch body/wiring is the same 70-73. Link to comment Share on other sites More sharing options...
Phengvang18 Posted August 11, 2020 Author Share #5 Posted August 11, 2020 1 hour ago, 7tooZ said: I think I have one I can send you? what year was your can manufactured? Mine is a 1970, I appreciate the help I actually just bought a new set from a seller for 150 dollars. I should’ve waited.. Link to comment Share on other sites More sharing options...
Zed Head Posted August 12, 2020 Share #6 Posted August 12, 2020 Over the images bump... Link to comment Share on other sites More sharing options...
dhp123166 Posted August 13, 2020 Share #7 Posted August 13, 2020 You can repair that with Plastic Welder Epoxy and it will be stronger than f@#$. Just make sure that each of the 3 sides is epoxied in place and the 2 pieces of the circuit board are lined up. It might help to unsolder the brake wire from the broken piece first. Remove any excess cured epoxy with a Dremel or the like, and reassemble carefully. P.S. JB Weld Plastic Epoxy is okay but I prefer Plastic Welder. Good luck! Link to comment Share on other sites More sharing options...
