Hi all,
My AC system is stock or at least what I been told.  Always use R12 and haven't converted to R134 yet.  The fitments on the compressor still R12.  Not like the R134a where one is bigger than the other and sometime caps color coded.
I read online, forums, including this one and seem like people stating that R134a can be run on R12 system provided flush all refrigerant, new fitments, run not as cool as R12, high pressure....
Knowing R12 is no longer available or at least at authorized AC shop.  The dilemma  I have is that I'd like to keep the car as stock as possible.  Which lead to parts hard to find and sometime impossible.
Seem like there is a company have the equivalent to R12 calls Frostycool R12a.
questions below:
- has anyone use this product before on the stock R12 system?
- I need an A/C drier though the fitment of the tube/pipe need to bend a bit to connect to this.  Is this one work well with stock AC? TCW  I also need a high switch.  I suppose unscrew the front bolt on the driver for the high switch.
Much appreciate
https://www.classiczcars.com/forums/topic/64339-1977-280z-ac-issue-xx-of-yy/
I think I found  the leak, hopefully the only place.  It is actually the schrader valve on the low input.  It leak so slow that I overlooked last time I did the soap test.
Instead of soap water, I just fill the valve with water and patiently wait for more than 5 minutes with laser eye fixated on the valve.  The leak is about one tiny bubble about the toothpick per 5 or so minutes.   I recheck it every 5 minutes or so and there it was, another bubble.  How do you go about fixing this with the refrigerant still full?  I put a cap with the o-ring in it already and hopefully good enough for now.
regards
regards
I thought it didn't exist, but I just searched. It exists! This allows schrader valve replacement without losing charge.
https://www.amazon.com/MASTERCOOL-81490-R134a-Remover-Installer/dp/B000KITSMI
Of course, this is for 134A service ports. I'm not sure if one exists for R12.
Edited by SteveJ
  • 2 months later...
Well, it was good for couple of months.  Found 2 other leaks.  One is on the back side of the compressor.  This will need a big o-ring and disassemble the compressor to fix.  The other is at the condenser.  Must have been a giant bee with a steel stinger that poked a hole.
have anyone try the Red Angel A/C seal?  What about using MAP gas to blaze the leak at the condenser?
regards
I know practically nothing about A/C, but I have two thoughts:
First is about the leak seal... I don't know any mechanic ever who has even remotely liked any of the sealing additives in anything. Tires, radiator, A/C. Anything. Ever. In fact, my local pro says he won't even evacuate a system if he's told that it has some sort of leak stop in it. Won't put his machine on it.
Second thought is about brazing the leak in the condenser. Again, I'm no expert, but there's no way I would try that while the system had refrigerant in it. The pressure will just blow the braze material away from the hole, and even more importantly, you absolutely do not want to light anything fluorocarbon on fire. Bad idea.
I’m more inclined to do the brazing.  But who knows, some one on this forum might have a very good result with sealing too.
I need to do more research, by research, I mean watch more YouTube, to learn how to braze.  Of course it will be off the car or at lease zero pressure before I do it.
  • 1 year later...
There's no way you will successfully braze an aluminum tube in an AC condenser. The age of the material and the thickness will just create additional holes. Just buy a new condenser.
Recently Browsing 0
