Posted August 15, 20204 yr comment_604243 Can someone explain the real world difference in engine operation using the different heat range spark plugs. How and when would you know which heat range your particular engine is wanting? Link to comment https://www.classiczcars.com/forums/topic/64344-bpr6es-bpr7es-bpr8es/ Share on other sites More sharing options...
August 15, 20204 yr comment_604264 real world, if you put a bpr8 in a stock Z engine it will foul badly, because combustion isn't hot enough to get the plug hot enough to self clean.if you put a bpr6 is a high compression tuned engine, the tip of the plug will melt because combustion is too hot.the right plug for the engine is one that doesn't foul and doesn't melt. Link to comment https://www.classiczcars.com/forums/topic/64344-bpr6es-bpr7es-bpr8es/#findComment-604264 Share on other sites More sharing options...
August 15, 20204 yr comment_604269 On 8/15/2020 at 2:21 PM, torynich said: How and when would you know which heat range your particular engine is wanting? AS jonbill describes, it's not what your engine wants but what will survive and stay clean in the engine. The engine will run exactly the same until the plug fouls or burns up. Link to comment https://www.classiczcars.com/forums/topic/64344-bpr6es-bpr7es-bpr8es/#findComment-604269 Share on other sites More sharing options...
August 16, 20204 yr comment_604291 So it sounds to me like the answer to the question is "Use the coldest plug you can that stays clean." Would that be accurate? Link to comment https://www.classiczcars.com/forums/topic/64344-bpr6es-bpr7es-bpr8es/#findComment-604291 Share on other sites More sharing options...
August 16, 20204 yr comment_604303 On 8/16/2020 at 1:11 AM, Captain Obvious said: So it sounds to me like the answer to the question is "Use the coldest plug you can that stays clean." Would that be accurate?yes, or the hottest plug you can that doesn't melt. Link to comment https://www.classiczcars.com/forums/topic/64344-bpr6es-bpr7es-bpr8es/#findComment-604303 Share on other sites More sharing options...
August 16, 20204 yr comment_604308 Or the medium plug that’s just right Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/64344-bpr6es-bpr7es-bpr8es/#findComment-604308 Share on other sites More sharing options...
August 16, 20204 yr comment_604309 Got it! Link to comment https://www.classiczcars.com/forums/topic/64344-bpr6es-bpr7es-bpr8es/#findComment-604309 Share on other sites More sharing options...
August 16, 20204 yr Author comment_604314 Thanks everyone ? Link to comment https://www.classiczcars.com/forums/topic/64344-bpr6es-bpr7es-bpr8es/#findComment-604314 Share on other sites More sharing options...
August 16, 20204 yr comment_604317 Kinda reminds me of Goldilocks and the three bears.. This porridge is too hot!" she exclaimed.So, she tasted the porridge from the second bowl."This porridge is too cold," she said.So, she tasted the last bowl of porridge."Ahhh, this porridge is just right," she said happily and she ate it all up.Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/64344-bpr6es-bpr7es-bpr8es/#findComment-604317 Share on other sites More sharing options...
August 16, 20204 yr comment_604325 Then she went over to the three little pigs house, blew it down, and ate grandma. I remember those stories... Link to comment https://www.classiczcars.com/forums/topic/64344-bpr6es-bpr7es-bpr8es/#findComment-604325 Share on other sites More sharing options...
