August 21, 20204 yr comment_604587 The only function of that arm on the front is for anchoring one end of the return spring? Seems like they could have put that somewhere else. Is there a center support tower? If there is, maybe on the rear side of that? Maybe at the back between the rearmost tower and the flange for connecting to the shepherd's hook? Does that use a custom adjustable length shepherd's hook? Link to comment https://www.classiczcars.com/forums/topic/64361-arghhhh-harada-intake-manifold/?&page=2#findComment-604587 Share on other sites More sharing options...
August 21, 20204 yr comment_604591 13 hours ago, 240260280 said: Thanks Alan! I'll install w/o the thermostat housing then grind off the unused hose fitting on the side of the housing that interferes and weld shut to prevent leaks. I have ~ 6 spare thermostat housing but none w/o side fittings. The later 260 and 280z have even more bits on the side. Here is an internet picture of a similar protruding fitting: I'm stating the obvious here, but - of course - that fitting is usually deleted completely and replaced with a flush plug when converting to triple carbs. That's hardly Harada Shokai's responsibility, and it certainly doesn't make their manifold a "POS". Wind your neck in. Link to comment https://www.classiczcars.com/forums/topic/64361-arghhhh-harada-intake-manifold/?&page=2#findComment-604591 Share on other sites More sharing options...
August 21, 20204 yr comment_604592 7 hours ago, Captain Obvious said: The only function of that arm on the front is for anchoring one end of the return spring? Seems like they could have put that somewhere else. No, it's a design that was based on the earliest Nissan Sports/Race Option triple carb inlet manifolds for the L-gata, subsequently adopted by the likes of Tomei and Datsun Competition in the USA. It properly accommodates the linkage to the front carburettor - the Sports/Race Option Mikuni 40PHH and 44PHH having their throttle linkages on the LEFT side of the carb body viewed from the carb inlet side - and gives the main linkage rod full support where it is most needed, unlike the 'rod end' type supports which typically hang the front linkage off the end of the main rod. Harada Shokai also chose to put a fully-adjustable main rod return spring on the end of the main rod, and it is a good solution - used by other manufacturers such as the early Sanyo Shokai manifolds. It works. For reference, Nissan Works items: Link to comment https://www.classiczcars.com/forums/topic/64361-arghhhh-harada-intake-manifold/?&page=2#findComment-604592 Share on other sites More sharing options...
August 21, 20204 yr comment_604597 I had to rotate the spring holder on the rod to just fit between my distributer and my thermostat housing. I took a pic, but I need to post it here.... I will get that up today. I have been very pleased with my Harada. Link to comment https://www.classiczcars.com/forums/topic/64361-arghhhh-harada-intake-manifold/?&page=2#findComment-604597 Share on other sites More sharing options...
August 21, 20204 yr Author comment_604603 Thanks Alan, That is what I thought. It was designed for very early thermostat housings that have no fittings in that area. I have these early housings on HLS30-00249 & 147 but not on my friends 1973. Link to comment https://www.classiczcars.com/forums/topic/64361-arghhhh-harada-intake-manifold/?&page=2#findComment-604603 Share on other sites More sharing options...
September 24, 20204 yr Author comment_606498 Got it in finally... found a 1/2" NPT plug and still had to grind it off to get enough clearance. Then the provided shepard's hook is too long and had to be shortened otherwise it hits the firewall? Grrrrrrr never again! Link to comment https://www.classiczcars.com/forums/topic/64361-arghhhh-harada-intake-manifold/?&page=2#findComment-606498 Share on other sites More sharing options...
April 20, 20222 yr comment_639518 Installed a Harada manifold on my 3.1 last weekend. Car started right up and sounded excellent. Only issue is I had to drill out the vacuum plug on the manifold. Big bummer I had to remove the manifold after the car started up perfectly. Anyone know the thread type and size ? Bspt ? Link to comment https://www.classiczcars.com/forums/topic/64361-arghhhh-harada-intake-manifold/?&page=2#findComment-639518 Share on other sites More sharing options...
January 28Jan 28 comment_673750 On 8/20/2020 at 3:17 PM, HS30-H said: Have a couple more on me: Trying to find info on this cold air box . How tall of velocity’s fit under there ! I’m doing ITBS and contemplating stack heights thanks Link to comment https://www.classiczcars.com/forums/topic/64361-arghhhh-harada-intake-manifold/?&page=2#findComment-673750 Share on other sites More sharing options...
January 28Jan 28 comment_673751 On 8/20/2020 at 3:17 PM, HS30-H said: Have a couple more on me: Trying to find info on this cold air box . How tall of velocity’s fit under there ! I’m doing ITBS and contemplating stack heights thanks Link to comment https://www.classiczcars.com/forums/topic/64361-arghhhh-harada-intake-manifold/?&page=2#findComment-673751 Share on other sites More sharing options...
January 28Jan 28 comment_673752 On 8/20/2020 at 3:17 PM, HS30-H said: Have a couple more on me: Trying to find info on this cold air box . How tall of velocity’s fit under there ! I’m doing ITBS and contemplating stack heights thanks Link to comment https://www.classiczcars.com/forums/topic/64361-arghhhh-harada-intake-manifold/?&page=2#findComment-673752 Share on other sites More sharing options...
January 28Jan 28 comment_673753 On 8/20/2020 at 3:17 PM, HS30-H said: Have a couple more on me: Trying to find info on this cold air box . How tall of velocity’s fit under there ! I’m doing ITBS and contemplating stack heights thanks Link to comment https://www.classiczcars.com/forums/topic/64361-arghhhh-harada-intake-manifold/?&page=2#findComment-673753 Share on other sites More sharing options...
January 28Jan 28 comment_673756 7 hours ago, madkaw said: Trying to find info on this cold air box . How tall of velocity’s fit under there ! I’m doing ITBS and contemplating stack heights thanks It's an R-Factory airbox originally designed for the S20 twin cam engine. I flipped it over and used it upside down on my L24. It has integral air horns welded to the base plate. Short/medium height Mikuni-Solex/Weber type standard air horns would fit if you modified the base plate to accept them. Link to comment https://www.classiczcars.com/forums/topic/64361-arghhhh-harada-intake-manifold/?&page=2#findComment-673756 Share on other sites More sharing options...
