15 minutes ago, Zed Head said:
Coil.
thanks,     any possible issue tapping in there?
also the headlight adjuster on the passenger side do not line up correctly is this a manufacture defect?
Edited by nefiwashere
With using the coil, you must use an inline fuse, or a short will stop your car dead. I will try to find another source,  but it won't be until much later today. I'm hitting the road for ZCON.
As for the headlight adjustment not lining up, that should be part of the factory assembly. Please post clear photos.
Go LED headlights,  reduces the current requirements to the point where relays are barely required to protect our sensitive old headlight switches.
either Dapper OE7’s or LED H4 bulbs in Hella or Bosch (or similar) housings is the way to go.
Dapper’s OE7 (and OE5) lights are astoundingly good and look OEM.  Bright white light and sharp cut off. 2.1 Amp each on low beam.
https://www.dapperlighting.com/products/oe7
BTW the blurry photo is caused by extreme speed and distraction of the photographer by the beauty of the subject matter...
Edited by zKars
IMHO, these look a lot more like they should for the Z.  I'd be curious to see how the other headlights look on the car though.  So, please post some photos.
Maybe we should make a Z headlight photo thread?   ?
Drivers side has plastic film.  That side the adjustment screws line up fine.
Passenger side they don’t line up.  I’ve tried making it fit but it will not sit correctly if I make the adjustment screws line up with the notched part.
Actually, you need to post a photos of the passenger side headlight out of the car (front/side/back). If it has two adjustment screws, then it's possibly one of two things:
1. Someone replaced the headlight in the past with a driver side headlight.
2. You somehow managed to mount the headlight 90 degrees out.
Without being able to look closely and not knowing much about your car, I would consider #1 first.
Getting back to an earlier topic in the thread, I think I found a better source for the DRLs. The washer fluid motor isn't close to the front, but you could use power from the blue/red wire, again with an inline fuse right after where you tap. That way if the fuse blows, you only lose the DRLs and you still have your wipers.
