12 hours ago, Yarb said:
I used the turbo/2+2 ZX 240mm Clutch and a lightened flywheel. This is a stroker motor correct?
Correct. 3.0 stroker.
now here’s a dilemma. The flywheel below was pulled from a 2+2 in 1995 or so. It was a ‘77 2+2 at Autogator in Sacramento. But I only unwrapped it today. What do I have? Did someone put a coupe driveline in a 2+2, or is this a 2+2 flywheel?
Looking at my 225 and 240mm hubs, yours looks like a 240mm. I took some measurements of the friction disc of both and a crappy pic of the difference in the hubs. Hope it helps.
225mm
240mm
Edited by siteunseen
Well after more than an hour on the phone with @Yarb today, I’m closer to a flywheel decision than I had been. Hopefully I didn’t get him in trouble with his wife as he only had 35 minutes to get to Publix and do some grocery shopping before they close. Thanks John!
