July 16, 20213 yr comment_625152 2 hours ago, 240ZBUILTBYME said: What shape burrs do you use for spot welds? And I'll add to that: Which die grinder type do you find works best for spot-weld work: straight? right-angle? Or does it depend on the weld location and accessibility? Do you see any merit in a variable-speed feature for this type of work? Have you tried the 'low-noise' designs and, if so, do they live up to their billing? Link to comment https://www.classiczcars.com/forums/topic/64416-240zbuiltbyme-1971-240z-hs-001063-project-georgia/?&page=18#findComment-625152 Share on other sites More sharing options...
July 16, 20213 yr comment_625155 19 hours ago, Patcon said: . Just noisy... Sound like your squeezing a cat. Link to comment https://www.classiczcars.com/forums/topic/64416-240zbuiltbyme-1971-240z-hs-001063-project-georgia/?&page=18#findComment-625155 Share on other sites More sharing options...
July 16, 20213 yr comment_625159 2 hours ago, Racer X said: Sound like your squeezing a cat. or a bad day at the dentist! Link to comment https://www.classiczcars.com/forums/topic/64416-240zbuiltbyme-1971-240z-hs-001063-project-georgia/?&page=18#findComment-625159 Share on other sites More sharing options...
July 16, 20213 yr comment_625164 8 hours ago, 240ZBUILTBYME said: Yep, the kit has a sprung drill bit in the center, I center punched then drilled a pilot hole with the sprung drill bit, once it was deep enough I put enough pressure to contact the actual cutter, still walked around. I just found the standard drill but type didn’t walk and then you don’t have to grind down any little circles after either. Just my experience with it. I'm talking about pre drilling the spot weld with a separate 1/8" drill bit then when you go to use the cutter the spring loaded drill is held captive. Actually it is the spring that is the problem, it doesn't push with enough pressure. I spent about $70 on that kit and I was determined to get my moneys worth out of it. Link to comment https://www.classiczcars.com/forums/topic/64416-240zbuiltbyme-1971-240z-hs-001063-project-georgia/?&page=18#findComment-625164 Share on other sites More sharing options...
July 16, 20213 yr Author comment_625169 32 minutes ago, grannyknot said: I'm talking about pre drilling the spot weld with a separate 1/8" drill bit then when you go to use the cutter the spring loaded drill is held captive. Actually it is the spring that is the problem, it doesn't push with enough pressure. I spent about $70 on that kit and I was determined to get my moneys worth out of it. I agree it probably is the spring that is the problem. Oh you mean drill all the way through both sheets of metal? But then you have to go back and fill all the holes? Link to comment https://www.classiczcars.com/forums/topic/64416-240zbuiltbyme-1971-240z-hs-001063-project-georgia/?&page=18#findComment-625169 Share on other sites More sharing options...
July 16, 20213 yr comment_625170 10 hours ago, 240ZBUILTBYME said: Yep, weld through primer. I’m using copper, upol brand. How do you like it? I've been using the zinc only formula they make and it works well for welding. I have not yet tested it for corrosion protection. Link to comment https://www.classiczcars.com/forums/topic/64416-240zbuiltbyme-1971-240z-hs-001063-project-georgia/?&page=18#findComment-625170 Share on other sites More sharing options...
July 16, 20213 yr Author comment_625171 4 minutes ago, ETI4K said: How do you like it? I've been using the zinc only formula they make and it works well for welding. I have not yet tested it for corrosion protection. I actually haven’t used it just yet, it’s sitting waiting, probably next time I work on the car hopefully. Copper upol is what most professionals use here in oz. not sure about corrosion protection but it’s got to be better than what the factory used back in the day......NOTHING! 😂 Link to comment https://www.classiczcars.com/forums/topic/64416-240zbuiltbyme-1971-240z-hs-001063-project-georgia/?&page=18#findComment-625171 Share on other sites More sharing options...
July 16, 20213 yr comment_625173 I have never used a low noise type. But if it's anything like the low-noise type air ratchet I have; it wont be very quiet. Maybe the low-noise type are intended to be hearing safe I was wrong... I have more than 6 or 7 . This isn't even all of them. Sorry about the rotation. It displays properly on my computer and in an editor... This is my tool of choice for spot welds. You can tell it's been hot. It's done hundreds of welds. I find a straight one is easier to use than the angle grinder because of the better leverage This is also really nice for dressing welds. A 1" Rolok The biggest problem with it is the pads go very quickly!! They are also hard to source and about $0.35 each. I normally dress welds mostly down with the 3" cut off wheel. Then fine tune with the 1" and 2" Roloks Link to comment https://www.classiczcars.com/forums/topic/64416-240zbuiltbyme-1971-240z-hs-001063-project-georgia/?&page=18#findComment-625173 Share on other sites More sharing options...
July 17, 20213 yr comment_625185 3 hours ago, 240ZBUILTBYME said: Oh you mean drill all the way through both sheets of metal? But then you have to go back and fill all the holes? Yes, but you have to weld the new panel on anyway. Link to comment https://www.classiczcars.com/forums/topic/64416-240zbuiltbyme-1971-240z-hs-001063-project-georgia/?&page=18#findComment-625185 Share on other sites More sharing options...
July 17, 20213 yr comment_625189 2 hours ago, Patcon said: I have more than 6 or 7 . This isn't even all of them. Methinks somebody's got a problem! Link to comment https://www.classiczcars.com/forums/topic/64416-240zbuiltbyme-1971-240z-hs-001063-project-georgia/?&page=18#findComment-625189 Share on other sites More sharing options...
July 17, 20213 yr comment_625196 I've bought a couple of lots of die grinders off industrial auctions for $25-$30 for 8 or 10 grinders. Normally most of them work. So I have a selection now 🙂 Link to comment https://www.classiczcars.com/forums/topic/64416-240zbuiltbyme-1971-240z-hs-001063-project-georgia/?&page=18#findComment-625196 Share on other sites More sharing options...
July 17, 20213 yr comment_625210 13 hours ago, Patcon said: I have more than 6 or 7 . This isn't even all of them. Does your wife know that you're using her bath towels in the garage? Link to comment https://www.classiczcars.com/forums/topic/64416-240zbuiltbyme-1971-240z-hs-001063-project-georgia/?&page=18#findComment-625210 Share on other sites More sharing options...
