A friend pointed out a very nifty electrical accessory he found.
It is a battery mounted multi-fuse box with various inputs and outputs.. Seems brilliant given the multiple fused outputs, both low and high current, and compact fit-on-top design.
And the price! A hefty £37 British pounds. Shipping for two of them cost me an additional £14 pounds. Pretty cheap.
Did not come with any fuses, but they common types. MIDI and MAXI
Hang a couple of relays on the side of this thing, and you could have quite the nerve center for any well equipped resto mod Datsun
https://www.autoelectricsupplies.co.uk/product/1100
This outfit has lots of other interesting electrical bits too. Check it out when you have some browsing time
A friend pointed out a very nifty electrical accessory he found. It is a battery mounted multi-fuse box with various inputs and outputs.. Seems brilliant given the multiple fused outputs, both low and high current, and compact fit-on-top design.
Love it!! Thanks for sharing. As you say, interesting other products too! [emoji106]
You would of course have to flip the battery round on a RHD car as the positive terminal is under the wing! [emoji15]
BTW, I’ve used AES for years - they are brilliant to deal with.
3 hours ago, grannyknot said:
That is a nice unit, have a look at their high torque starter for Datsuns, pricey but pretty. https://www.autoelectricsupplies.co.uk/product/1114/category/218
Wow! Datsun parts on AES! That is some impressive starter.
It is indeed! Recognition at last ;)
WOSP who make the starter, are also a good British company, who make seriously high quality stuff. When I was deciding to rewind my 280zx alternator for more juice at lower RPMs (due to the half sized pulley on the ATi crank damper), I contacted them and they have a very impressive selection of stuff but not the cheapest around. You get what you pay for in this instance.
http://www.wosperformance.co.uk/
