1977 280z
HDAtom
Hello!
I am starting this build thread because of how much information I was able to get from posting a simple picture of my engine and asking what I should do with there. There was tons of support and I am excited about sharing my build process here and adding more information into the mix for future builders. I am hoping this will also keep me more accountable and will allow me to actually finish the car. I only have a short time until I begin my next job and I want the car to be working by then. I will be working hard to get it there. This is my first restoration and I don't have an insane amount of experience with cars. I have swapped an engine (oem) before, rebuilt a t5 transmission, and have completed numerous smaller projects on my families cars. Anyways, this is going to be a fun process and I hope to get something that runs, drives, and can say I saved it from the scrapyard. I plan to update this every day I work on the car, which should be 7 days a week about 6-10 hours a day. So hopefully expect a post every day to see progress! These will most likely just be me rambling like this one is.
Goals (hopes and dreams):
  • Everything will be DIY (except machining...)
  • I hope to have this car painted by October 7th and out of my parents garage.
  • I hope to have the car running and driving by the 31st.
  • I dream of having the car relatively complete (it never will be complete) by the end November 30th.
Budget (LOL)
I bought the car for $1000 and I hope to complete the car in the range of 15-20k (including tools), but I will have to see what happens... By the time I am done painting I should have about 4k into the car and tools
Other stuff:
I have a lot of planned "upgrades" that I want to do such as a full TTT lower half of the car (I hate money), new brake / fuel lines, a nice engine bore and new pistons (KISS), and new pretty much everything that's in the engine bay (alternator, AC, starter...), but I will have to see how it goes...
There are some big questions still out there lingering in my head such as if a full TTT build is worth it (probably around 8-10k) and how will the ride be. I am quite young and am not too worried about the ride, but more with noise as it annoys me a lot. Also paint color... I have about 5 days to figure out which color I want, I think I want it to be red... I wanted to get the paint in original 110 red, but I think it is a little too orange for my taste and probably won't go with it (this is what the original car's color is).
I took some photos today, I have just completed stripping the engine bay (I will be bending current brake / gas lines out of the way as all the hex ends have been marred and don't work anymore, I figure bending is better than cutting) I will be able to give more up close photos of the damaged areas when I actually get to welding new stuff on!
I will also be keeping all of the images and files found here in this shared OneDrive folder as I have noticed many people's photos and things seem to go missing.
Here is my first picture dump!
Safely #1, you will probably see a lot of PPE around in my photos...
Interior was mostly stripped when I got it... I have a box of interior parts I hope will fit back together...
There should be some much better picture tomorrow when I am able to get this cleaned up and start stripping the paint off and seeing how far the rust really goes, I have a lot of work to do... It was at the end of the day and there was low light so pictures arent the clearest.
I would save all your budget for metal work.
Regarding "upgrades" (glad you put them in quotes btw), get it running with all the metal work done. Test drive it as is see how you like the ride. That way least when you end doing "upgrades" you will know if they really are. I am sure there are a lot of good products out there, but seems to me unless you really know how to select the right stuff and set it up properly, there is at least the possibility if spending money and down grading the actual performance of the car. These cars were designed to give nice sporty (by 1970's standards which was a pretty low bar) daily driving.
Edited by Dave WM
I really hope it doesn't take too much of my budget to do metal work ??, I only budgeted about $500 for metal. I also know how to weld so I will be doing all that work myself. Almost everything seems to be surface at this point, with the exception of the rocker panels, battery tray (lol I didn't even show a picture of this and its a huge hole), little bit in driver floorboard, and the 2 tail sections. I am probably missing a few obvious sections, but I don't believe it is terrible. We will see....... I also plan on making my own battery tray and doing everything out of sheet metal (bending myself ect...) as well as not expecting a perfect job.
This car sat for 5 years with the previous restorer and I am not interested in leaving the car in the driveway. She wants to hit the road, even if not in perfect condition (she told me ?).  My frame rails are dented but not destroyed, I am also not redoing the bottom as it seems to have held up well and I don't have a rotisserie, nor do I have time / space. Hopefully another time though!
This is why I was hoping to just go with techno toy for the entire build. It will be expensive, but I will also get to geek out with all the customization and get to learn a ton about how to tune a cars suspension, with a system that was setup to hopefully work with each other. I am also hoping for reliability and workability with those nice strong powder coated parts...
...trying so hard to hold it together here.... such optimism! I love it when people have plans to be done "ina few months" for "a few thousand dollars at most..."
While I am 6 years and $45,000 into my $10,000 6 month restoration...!
One can dream I suppose!! I wish the OP all the best and hope it works out for him.
  • Thanks 1
Some of us just become very good (quick anyway) at taking things apart and putting them back together again.  You could take the piecemeal route.  Start putting things together, make a running car, then fix the stuff that needs fixing.
Everything that you're planning will have delays associated, the farther you go the more there will be.  Many of your parts are going to be rusted and/or corroded, like probably all of the hydraulic systems.  The electrical is going to be difficult.  Drive train probably has missing parts that you'll need to source.  Won't know until you're putting it together.
The delays in what ZH mentions is an important consideration. can you stand to have you car all torn apart for long periods, not lose stuff, etc...
Why I advocate for getting it safe (metal work so it will protect you, then brakes so you can stop, then engine so you don't get stranded. everything else from there is gravey that you can pour on while still enjoying driving it.
Personally if my car is down for a week I get sick not being able to drive it. I would only take on a project car IF I had a daily to keep my addiction in check.
I will echo what all the others have said so far.  You are ambitious for certain!, and I'm not trying to dissuade you.  But reality will let itself be known once you get started.  Welding skills are a huge plus and will relieve some of what is ahead of you,  but I think you can count on a lot of surprises, missing parts and delays. Just about every one on this forum has experienced all of those things and more.  It's all part of the fun of bringing these cars back.   The depth of knowledge here is amazing and this is absolutely the best group of folks to get honest help and advice about the Z.   So prepare for a lot of pleasure/pain and enjoy the adventure.
I would expect way , more than $500 for metal repairs! and that's doing it all yourself.  I also wouldn't make any panel that is commercially available! A stamped panel is harder and will make a better repair. Also if the metal work isn't done really well it really hurts the value of the car. Don't scrimp on this part!!
Thanks everyone for their replies, really awesome to see all this. But ignorance is bliss ?. I really like to approach things with a very optimistic view and will usually fall slightly short of the stars. Believing you can do something is half the battle, the other half is not getting in over your head...
This car will NEVER be finished and I don't expect it to be, when I said I wanted it "complete" I was more talking drivable as a daily. This does not mean 100% reliability, but generally commuting in it. This car will eat away at my wallet for decades and decades.
This is definitely the plan, pretty much anything that doesn't need to engine to be out to be worked on won't be improved until after it is driving.
I am actually planning on replacing all of this. I want to make new lines for all of this and when I put new brakes on I will do new master cylinder, booster, ect. Pretty excited to make the lines tbh, will go stainless for these.
My electrical actually seems to be in really good condition. I was expecting to create a new harness, which I was quite excited about, although after I took it apart everything seems to look decent. I will need to do some better butt connectors in places but it isn't too bad. This is with the exception of the fuel sensor plugs things which are all broken, (honestly idk what they are just yet) which I know I can buy a kit to replace those.
This is pretty much my philosophy, except I am going engine first so when there are lead times there I can switch to other things like brakes
Maybe I am too optimistic about this, but I think if I can stay focused I will be able to switch to different parts of the car when there is a problem with 1 part.
In terms of stamped paneling, I think the only real area that I have rusted is the tail plate, but when I looked at those online, they weren't even stamped in the area that I am working on. I may cut out both sides and make them match... I have also not looked under the wiper area, which could be a HUGE mess, who knows. For the floor pan I plan to just patch the small section and move on. I am also not too concerned with resale value, I hope to drive it until I am inevitably unable to dodge someone who will then hit me.
Updates for today...
Today sucked..... Pretty much broke my battery powered orbital sander and then got a pneumatic one with the hopes and dreams that my dad's pancake compressor could keep up. It could not... So I spent the day looking for a bigger compressor and a good solution for our workspace in the used marketplace. Didn't get too much sanding done and I am leaving my engine bay paint stripper on overnight.
Cover the paint stripper with cling wrap. It will enhance the process by removing oxygen and stopping the stripper from evaporating.
I am the embarrassed owner of three air compressors. Each one bigger than the last. The single stage 60 gallon industrial one is adequate but I keep ogling number 4 with a two stage compressor head....
Enjoy the process!
Thanks for the tip, the stripper definitely evaporated.
I am just trying to run my sander on the compressor. My sander says I need about 3 cfm @90 to run it. I think I am able to pickup the dewalt 4.5 gallon 235 psi tank, 5 cfm@90 for a reasonable price from someone online. Do you think this will be able to run it? I have also been looking at buying additional 10 gallon 150 psi tank from HD for $30 (on sale if anyone else is interested) and making that into additional tank space. Although I think with the low PSI, it won't help that much and will need to be post regulator anyways. I am also ok with buying a 15-30 gallon one and selling it after the process, although with this smaller one, it would work with our tight garage setup. This would not be used for painting.
  • Who's Online   0 Members, 0 Anonymous, 608 Guests (See full list)
