I am truly not sure if I ever started the car not in it or seat belt unhooked.  I only drove the car 3 months before its 2 yr. storage.  I was going to test this option tonight if I can get to the garage.
I know one thing if it works you might hear the scream all the way to you there!
21 minutes ago, SteveJ said:
This is what I posted in the past on the seatbelt interlock relay:
I knew that you knew about the interlock but typically don't read much about them, because I don't have one, and they seem like a real pain.  Kind of like the BCDD.  One of those things that you hope you never have to deal with.
Your jumper at the plug is the elegant solution.  I was imagining cutting or tapping wires to get around the switch  Didn't know there was a plug, but of course there is.
But.  If I read the diagram right and the anthony_c's posts, the interlock does not cut power to the coil.  Just the starter.  So that coil power problem will still be there, for iscnetwork.
You are correct. That's why I was suggesting the ignition switch at the beginning of the thread.
Edited by SteveJ
When to the garage, tested to see if I need to be all bucketed up.
My interlock is disabled.
In all of my tinkering the yellow wire going to solenoid has "juice".   But did not have any time to put everything back together and see what will be my next battle (pray NONE).
Thanks everyone.  I should have some 'garage time' tomorrow.
On 9/28/2020 at 3:14 PM, zclocks said:
Here's a couple of pix of the coil/res. Let me know if you need more
Which color goes to the coil + terminal.  I really would not like to take my educated guess. Thanks.
Edited by iscnetwork
If you don't mind I need a couple definitions.
START = all the way clockwise but not trying to kick in the solenoid / starter
The yellow or whitish wire is the one to disconnect?  (It goes from battery to inside of the larger wiring harness which goes into the dash board. )
[Guessing here, the only thing connected is the Accessories wire that runs directly from the + battery lead connector. ]
[the 2 red wires are what replaces the Yellow Solenoid wire with the aftermarket relay. If I ever find all my wiring, I plan to replace those with yellow & yellow / red.]
thanks.
added more info
Yours is red now.  The one that pulls off by hand, no wrenches needed.  With it disconnected the starter solenoid will not energize, only the fuel pump, and CSV, etc.  The engine won't spin so you'll hear the pump.  It's a good way to run the pump and flush out the system with fresh fuel, if you're worried about that.  You can also use it to check your fuel pressure, without engine vacuum.
Edited by Zed Head
