Posted June 4, 200321 yr comment_39696 So here's a possibly stupid question the answer to which has escaped me in all my reading on coil-ever conversions (cut/weld housing to relocate perch). How do you know what size cartridge to order? And where do you go to order it? Do manufacturers have a 'private' page page where they disclose the actual dimensions of the cartridges (without a make and model obviously)?steve77 Link to comment https://www.classiczcars.com/forums/topic/6457-coil-over-cartridge-sizing/ Share on other sites More sharing options...
June 4, 200321 yr comment_39748 Zv,You might want to give Ground Control a call about your cartridge requirements. I have gone through the exercise of cutting my struts down an 1.5" and installed their coil-over kit. My memory is not always the greatest, but I believe I purchased the strut cartridges from GC also. Anyway, they will most likely help you out. Link to comment https://www.classiczcars.com/forums/topic/6457-coil-over-cartridge-sizing/#findComment-39748 Share on other sites More sharing options...
June 4, 200321 yr comment_39749 Zv;Check out the "Alternative to Ground Control ?" in the "Open Discussions" Forum... Several other companies who manufacture and market coilover kits are identified.Good Luck! Link to comment https://www.classiczcars.com/forums/topic/6457-coil-over-cartridge-sizing/#findComment-39749 Share on other sites More sharing options...
