Posted October 21, 20204 yr comment_608674 I’m trying to adjust the passenger side hinges on my 73Z. The door is hard to close and the gaps don’t match. In the 73, the hinges are still threaded, which is awesome, because I didn’t want to take the fender off. Unfortunately, there are a slew of relays and connections mounted to/through the fiber board interior panel. I’m down to one screw, but am not contortionist enough to get it out. Has anyone done this before? Do I need to take the dash out? Thanks! Link to comment https://www.classiczcars.com/forums/topic/64592-73-door-hinge-access/ Share on other sites More sharing options...
October 21, 20204 yr comment_608698 On 10/21/2020 at 6:36 PM, 73avocado said: Do I need to take the dash out? Thanks! No, the dash doesn’t need to come out. It is a bit tricky, but the last screw can be removed, and the kick panel after that. Link to comment https://www.classiczcars.com/forums/topic/64592-73-door-hinge-access/#findComment-608698 Share on other sites More sharing options...
October 23, 20204 yr Author comment_608773 Ok, I’ll do some stretching and try again. Thanks. Link to comment https://www.classiczcars.com/forums/topic/64592-73-door-hinge-access/#findComment-608773 Share on other sites More sharing options...
