just thought I would note this and see how others are doing
I wipe the dip stick, insert then pull out, then wipe the bottom and sides of the dip stick after drawing out to mark on the card. H and L are the top and bottom of the hatch marks, mileage is noted on the bottom. I started above H with a new Nissan filter and 5 Qts of 20w50 VR1. My goal is oil and filter every 3k (or 6 months if that comes 1st) but looks like will be adding 1 Qrt pretty soon. The engine has I think 110k (could be more of course but I suspect this is correct based on overall wear). Plug insulators look fine, I get some black carbon build up on the edges, fairly dry. I have no external oil leaks, no oil in the radiator. I drive very conservatively (2.5k to 3.5k rpm) last check of compression was about 160psi +- 5psi across the board. IIRC the bottom of the hatch marks puts you at 1 quart low. The oil pan slopes so I suspect the readings on the dip stick will be non linear to usage.
Edited by Dave WM
https://www.classiczcars.com/forums/topic/64618-oil-consumption/
10 minutes ago, 7tooZ said:
Is this a warm or cold engine?
dip stick readings are done cold, and at the same location, a garage on a level floor. I like to allow time for the oil to drain back from the top of the head.
Edited by Dave WM
