I need to buy panels for the left and right side below each door handle... is this called the rocker panel? I usually buy from Z Car depot but i dont see anything there. I might be calling it the
wrong thing?
thanks
https://www.classiczcars.com/forums/topic/64622-is-this-the-rocker-panel/
Yep, looks like it from your picture.  Check out KlassicFab Vintage JDM, I've been hearing very good things about their parts.  If you do not see what you want on their website just contact them since their website is not current with all their parts (they are constantly rolling out new items).
What you are pointing to is the inside rocker panel, this is what you are looking for, they come in left or right.
https://kfvintagejdm.com/shop/datsun/inner-rocker-left-side-datsun-240z/
There should be a long curved sheet metal piece that is vinyl covered to cover the inner rocker. It attaches with some small sheet metal screws. The piece has a smaller curved section on the top that secures the door weatherstrip along the pinch weld.
