Posted October 27, 20204 yr comment_609083 Hi all, Recently pass smog test. Been enjoying it every chance I get. Even volunteer to do errands for wife just so I can drive it!!!! I've notice the steering wheel can only make one full circle and the "distance/length" of the tire doesn't cover much. to put it into perspective, I'm having trouble making a 2 lands U-turn. What I mean is the other day I at McDonald's drive through, I had trouble making a right U-turn. My Van and sedan seem able to make a right U-turn quite easily. Of course it inches outside toward the other land a bit, but not as much as the Datsun. I had to back-up a bit in order to make a turn. I had to make a three-point turn. A bit of embarrassed as it was lunch time and was quite a bit of long line ... ;) When I rebuild "grease and new bearing, seal replaced", I noticed the travel rod not that long/far. Is this normal or do I have to do a "drift" at the u-turn!!!! regards Link to comment https://www.classiczcars.com/forums/topic/64623-77-280z-steering-wheel-travel/ Share on other sites More sharing options...
