Cool Tool of the Day. (CTOD)
zKars
Gland nut removal tool ....
Old bracket + 8.8 bolts and a step drill to widen the centre hole.
cc39d30097b41572dfce2ff081262660.jpg&key=216389ccff8b1bd5292b23f116162b826f4850387086837aee0eca44fd6a780c
62d86567b68c131a425cc51fd31a6545.jpg&key=f9439f58b40e2a6ea8858b5bd5a48c11ce1a336e6ed63846a21e8c523c00566c
33c5e8c5e471f679703c796a1d3aa5b0.jpg&key=eb52b8fbd6896701f642291f895ef68e9da2136af76afa6aa6a31b775bb7b7f6
50aec901b1eafcba0490baf675076281.jpg&key=80829bcddfcb4ed1f4de314468960784a93a09e75aacc98a8f466b2646833ebe
Just add hammer. 2lb is ideal. Oh and bolt strut bottom to the garage floor pre-drilled with a couple of rawlplugs in place.
87a795fdf75707d1958a6acd6f95bd1a.jpg&key=cb98d29c6dae991942ced57e54431d7e89e3a8f5fbdedd3a5ef0c4385ab6ca41
 Clearly the original gland nut needs a couple of holes drilled but the new ones from Koni come pre-drilled.
badbbe7b650d214af7a88b4621e92258.jpg&key=9ee88fc6280f6cbe8077d76a159edb35b9d62d670ff8c29f1b08155c49b28a26
  • Like 4
Just stare at that little beauty for a minute. The brake line threaded into that little remnant of an old brake line welded to the bar is the secret weapon.
I already use the CuNi tubing and have for years. It is very soft and forms nicely in my powerful hands. However, there is one bend type that is always challenging and of course occurs frequently. A tight curve near the end of the tube. Bending the end of the tube requires more force as the leverage is reduced with shorter length. Don’t believe me, make a 180 in the middle of a 12 long piece, then make it again at the end. My finger tips cringe at the thought of it.
Dang, if only there was a way to safely, easily grab the end of the tube in a vise grip or something without screwing up the threads or crushing the tubing and giving me an extension handle to increase leverage. BINGO! Thread the tube nut into an old female brake fitting welded to the end of a scrap.
Consider that little devil tight S curve on the stock front caliper.  TWO tight 180 bends near BOTH ends! Impossible to make it nice and pretty and kink free!
Not any more.
I made a bunch. Need any?  All of these were created on the car on real stock calipers and strut tube mounted hose ends, so they fit perfectly. They are R and L sided. They took literally 5 minutes each to bend and fit.
Yes, they are not the exact same shape as the stock ones, sorry. Those bends are ridiculous.
Edited by zKars
  • Like 3
Yes there is a 1.25 diameter roller thing at the other end to help you form tubing as well if and when that comes in handy.
That wheel is a screen door bottom guide roller. It has a 1/4” groove, bit bigger than the 3/16 tubing, but works just fine.
  • Like 3
  • 4 months later...
@zKars Nice and simple, which is the best kind!  Were you able to hand-form the S-bends without kinking?  I've used a steel rod inserted into the end of the tube (also works for straightening).  Not great at all, but expeditious!  I think I will fab me up one of yours for my pending steel lines replacement adventure.
Also really like the TC compression tool.
15 hours ago, grannyknot said:
Here's a modification I did to a socket to get at that main nut in the 4 and 5 spd transmissions, can't remember what the size of that nut.
I started at CO's post and worked my way backward and I really thought you were going to describe how to make a bong out of a giant socket.
Edited by Zed Head
  • Haha 2
  • Who's Online   0 Members, 0 Anonymous, 455 Guests (See full list)
