Spark plug fouling! PCV Valve check?
jalexquijano
I doubt that the PCV is causing the fouled plug. The PCV is just a one way valve. Shake it, can you hear it rattle, good. Now blow in each end. Blowing in one end will be impossible but the other end should free flow. If it's blocked either soak it in lacquer thinner or buy a new one.
