On my path of recovery from my ill fitting RHD header, I need to find a new L24 block crankcase breather tune as I had to cut mine down. I'm also after a series 1 heat shield and if possible a valve cover vent tube.
Apologies in advance for not posting this in the parts wanted section but those areas dont appear to see much traffic.
Thanks in advance, cheers.
Edited by ollie
  On 10/28/2020 at 5:52 PM, SteveJ said:
Steve, I think you mean this link. https://www.carpartsmanual.com/datsun/Z-1969-1978/engine-240z-260z/emission-control-device #4 The part number is correct 11830-E3000 (discontinued.)
Yours went to a s12 Silvia. (?)
No offense intended.
If the other leads don’t pan out I have some block breather tubes, valve cover breather elbows, and maybe a S1 heat shield. All used, but all restorable. PM me.
Edited by zKars
