Few more updates on the Z. Worked on rebuilding the quarter windows, finished up the vapor canister install, and got the antenna/speaker bracket in. Next I’ll get the wiring harness routed and have the hatch area just about done.
Edited by CW240Z72
2 hours ago, dutchzcarguy said:
When i look at the pic above.... i would make a cable from the white connector straight into the motor.. all those connectors.. it's like modern cars.. to much connectors..to much failing!
The idea for the amount of connections was to allow the motor to be unplugged and swapped out without splicing into the harness. There’s also a 30 amp relay in the system that’s needed for proper function. It’s not a simple wire to wire connection for this upgrade unfortunately.
3 hours ago, dutchzcarguy said:
I agree, maybe those plastic caps are honda? As far i've seen Datsun had the plastic bag..
Plastic cover is 100% original to the car. Second Z I’ve had with one, as it was for both CanTechZ and jfa.series1 above.
