August 30, 20213 yr comment_627766 I would be in for one of those Link to comment https://www.classiczcars.com/forums/topic/64674-restoration-of-hls30-12070/?&page=16#findComment-627766 Share on other sites More sharing options...
August 31, 20213 yr Author Popular Post comment_627810 First print complete. A little tweaking on the hole spacing and it should be good. I need to double check that the overall height isn’t an issue for the console. Link to comment https://www.classiczcars.com/forums/topic/64674-restoration-of-hls30-12070/?&page=16#findComment-627810 Share on other sites More sharing options...
August 31, 20213 yr comment_627812 Looks great! Link to comment https://www.classiczcars.com/forums/topic/64674-restoration-of-hls30-12070/?&page=16#findComment-627812 Share on other sites More sharing options...
September 2, 20213 yr Author comment_627926 Second print complete with a few minor tweaks. I’m very happy with the fit. Just need to make sure it’ll clear the ash tray Link to comment https://www.classiczcars.com/forums/topic/64674-restoration-of-hls30-12070/?&page=16#findComment-627926 Share on other sites More sharing options...
September 2, 20213 yr Author comment_627927 The original console was structurally in good shape, but sun baked causing the textured finished to crack. Since there aren’t many of these floating around I decided to restore it. I first sanded down the textured finish where it was damaged and used body filler to fill in the deeper hairline cracks. This was then top coated with a quality high build primer, and then sanded down to perfect the surface. SEM sells a great interior/exterior textured coating. Very lightly applying it, a thin texture was sprayed where the original had been removed. Finally it was top coated with a trim paint from SEM. Very happy with the results. If you look at the closeup finished photo, the flat area of the console behind the shifter opening received no textured finish and was left untouched apart from the primer and top coat. It now blends seamlessly with the new texture on the sidewalls of the console. Last photo is of the SEM products used to do this. Give it a go before buying a repop! Link to comment https://www.classiczcars.com/forums/topic/64674-restoration-of-hls30-12070/?&page=16#findComment-627927 Share on other sites More sharing options...
September 7, 20213 yr Author Popular Post comment_628186 Remaining body work and paint completed over the long weekend. Link to comment https://www.classiczcars.com/forums/topic/64674-restoration-of-hls30-12070/?&page=16#findComment-628186 Share on other sites More sharing options...
September 16, 20213 yr Author Popular Post comment_628604 Couple details updated on the Z. Working on the exhaust system now, should have that wrapped up soon. For now, much of the body has been reassembled. New/replated hardware used throughout, and picked up an excellently restored set of side marker lights and license plate light from @jfa.series1. Original turn signal housings received a deep cleaning, lens polished, and new hardware sourced. Link to comment https://www.classiczcars.com/forums/topic/64674-restoration-of-hls30-12070/?&page=16#findComment-628604 Share on other sites More sharing options...
September 27, 20213 yr Author Popular Post comment_629055 Few updates over the weekend. Cleaned up the ash tray on the Z. Was very fortunate this wasn’t broken in a million pieces. test fitted the muffler and mounting brackets. Fit looks great. Got the air cleaner finished up and installed. Few more routings jobs left and the engine bay will be buttoned up. I also pulled the steering rack out and swapped out the U-joints. Didn’t realize the slop there was in them until after the column was reinstalled. Now it’s as tight as a drum. Link to comment https://www.classiczcars.com/forums/topic/64674-restoration-of-hls30-12070/?&page=16#findComment-629055 Share on other sites More sharing options...
September 27, 20213 yr comment_629090 No expenses spared on this one. One question, is this going to be a driver? YOu have set the bar here. Link to comment https://www.classiczcars.com/forums/topic/64674-restoration-of-hls30-12070/?&page=16#findComment-629090 Share on other sites More sharing options...
September 27, 20213 yr comment_629091 Beautiful as usual, could you share the details on the steering rod Ujoints? Link to comment https://www.classiczcars.com/forums/topic/64674-restoration-of-hls30-12070/?&page=16#findComment-629091 Share on other sites More sharing options...
September 27, 20213 yr Author comment_629093 On 9/27/2021 at 9:50 PM, DC871F said: No expenses spared on this one. One question, is this going to be a driver? YOu have set the bar here. I would hope that me and whoever owns this car next apprentices it and drives it. Hate to see them sit. Link to comment https://www.classiczcars.com/forums/topic/64674-restoration-of-hls30-12070/?&page=16#findComment-629093 Share on other sites More sharing options...
September 27, 20213 yr Author comment_629094 On 9/27/2021 at 9:50 PM, grannyknot said: Beautiful as usual, could you share the details on the steering rod Ujoints? Here’s some more info on them: ATV700 is the PN. You can pick them up on Amazon, eBay, etc today. They’re an affordable and direct swap into the Z! Link to comment https://www.classiczcars.com/forums/topic/64674-restoration-of-hls30-12070/?&page=16#findComment-629094 Share on other sites More sharing options...
